Speaker volume level
NeilGabriel
My rears in my HT system are playing at very different volume levels. I switched output connections and it is the speaker. I have to spike one up about 2.5db to get it to be as loud as the other rear...they are same disatnce from sitting area and in same place relative to wall, etc.
I am guessing that one of the two mids (10B's) is out on the quiet speaker....will I need to pull them to determine this or is there a less invasive way? Thanks...
ng
ng
Post edited by NeilGabriel on
Hey Mike, are you getting any sound out of the tweeter? If it is blown, there will be lower output.
It can be difficult to tell which MW is out with them both in the cabinet, they will both "move" so taking each one out and checking it may be the only way to be sure.
stubbySRS 3.1TL
Harman Kardon Citation 5.1
Anthem AVM2 -
thanks...sure thought I had sound from tweet...but I will check....I was certain I had full sound from both....but I had checked them out side by side and not individually....
anyone know what mid these use now? Series II 10B?
ng -
Did you put your ear to each driver of the lower volume speaker to see if one sounded off?..... ><////(*>
thinking back...I am sure the speaker was playing equally loud...after hooking up to a new system, I did accidentally blast some sound through....if I did something to the tweet, will it reset itself...or would the tweet just need to be replaced.
I will listen cloiser to the mids...unfortuantely, I am at a hospital in St. Louis with wife's mom....no fun at all....did pick up a 7- pair of short grill 5B's....drivers look great...
Anyone know off top of head if 10Bs use same mid as 5B's? -
NeilGabriel wrote: »
Hey Neil sounds like you guys are at Barnes jewish hospital right? Tell your wife not to worry, they have some of the world's best specialists working there. Sorry to hear and hope things get better.
regards,
Matt
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
