Speaker Cable Splitter
swb502
swb502 Posts: 112
Hello All!
I’m seeking the collective wisdom of the board again with something I’m guessing is very straightforward. I have a monitor based system and I find it distraction that the Monitor 70s have 4 drivers and the center only has 2, I would like to have 4 drivers there as well. This has driven me to look for another CS2 to put next to the one I already have.
Now where the question is, I purchased a new receiver from the board a Yamaha RX-V2700. I was reading its manual and it said it, can drive 4ohms but 8 is recommend. So to get 8 ohms I want to wire the two Cs2 in parallel. This would require a positive and a negative splitter to run to each speak. I can’t feed to find a splitter for audio cables. I have an RCA one for the subs, but can’t find one for speaker wire.
So my question is, do I just twist the 3 wires together and toss some heat shrink over it? Or is this completely the wrong way to do this? Thanks.
Bill
Work in Progress HT
Receiver- Yamaha RX-2700
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2 x 2
Surrounds- Polk Audio Monitor 70
Rear: Polk Audio Monitor 40
Sub- Polk Audio PSW505 x 2
Projector: Epson 8100 HC
Screen: Visual Apex 120"
Blu-Ray- 60 GB PS3
Post edited by swb502 on
    Toolfan66 Posts: 18,067
    edited October 2010
    To me the best way to do this is with an external amp.
    1) getting a RCA splitter for your center channel preout on the back of the receiver ( if yours has one) then one IC going to one channel of the amp and another going to another channel of the amp then of course hooking up both center speakers side by side..
    I don't see any other way of doing this properly but others may chime in and school me..
    Larry.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited October 2010
    If you wire them parallel the load on the receiver will be 4 ohms. If you wire them in series they will be 16 ohms. Neither way requires a splitter, just wire.
    http://www.termpro.com/articles/spkrz.html
  • swb502
    swb502 Posts: 112
    edited October 2010
    So which what is the correct way? I can't figure out how to do series without two splitters. And I should have said above 8ohm. The receiver said it can driver great ohms but not less then 8. One review I found had it driving 32ohm.
    Work in Progress HT
    Blu-Ray- 60 GB PS3
    txcoastal1 Posts: 13,513
    edited October 2010
    Still not recomended but series is created by you taking pos to one speaker and the neg to 2nd speaker and a common wire joining the pos and neg from each speaker thus creating 16ohm from 2-8ohm spkers or 8ohms from 2-4ohm spkers. We do this with paging systems but take a 2nd pair of spkrs in same config and putting the 2 pairs of 16ohm series in parallel to bring back to 8ohm at amp...still not a great idea with home audio if you want good sound but I can stand corrected if someone else chimes in..my .02
  • Face
    Face Posts: 14,340
    edited October 2010
    Bad idea, running 2 speakers in series and their crossovers will interfere with each other. Besides the fact that you will have some comb filtering(cancellation).
  • swb502
    swb502 Posts: 112
    edited October 2010
    So overall this is just a bad idea, and I should suck it up? The external Amp seemed like a possible solution and just use a spliteron the pre-amp signal.
    Work in Progress HT
    Blu-Ray- 60 GB PS3
  • WilliamM2
    edited October 2010
    No, even with an amp, you will still have comb filtering. Just use one center, it's all you need.
  • nguyendot
    nguyendot Posts: 3,594
    edited October 2010
    or buy a bigger one.
    Main Surround -
  • Outfitter03
    Outfitter03 Posts: 563
    edited October 2010
  • mantis
    mantis Posts: 17,412
    edited October 2010
    You wann do all this just because you think your center channel should have the same amount of drivers your main speakers have? Thats the stupidest thing I have heard in a long while.
    If it really bothers you put the grills on. As long as you have the correct matching center , sound quality will not be an issue.
    Dan
    edited October 2010
    mantis wrote: »
    Don't visit the cable threads much do you..:p;):D
  • mantis
    edited October 2010
    I do and I can't bare it. I try to educate people on wire.
    Dan
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited October 2010
    I think I've seen wires running from one speaker to another and then to the amp. How and where does one set of wires h/u to. Is this the bi-amp , I'm really lost here. Also I've seen giant JBLs w/ pwrd subs wired into them . Do these amps stay on all the time and to what end, shouldn't your sub be indy from your speakers. These looked as if they weighed about900lbs and only for the biggest rooms .to me if I had a room that size it would go to Klippschorns........ps , more sites against $ cables than less expensive......lw
  • leftwinger57
    edited October 2010
    Oh I knowI constantly rail against spending big bucks on wire, so set me up w/ a blind test, and believe me I'll tell you my honest opinion. Listen I'm a member of the Dead site and you know how wacky those guys can be. My first post wailed into that band that
    when ther'e good they are the best at what they do, but when there bad there HORRIBLE, so you see I do say it as truthful as it may be. Sorry for ranting bad mornining
  • cstmar01
    cstmar01 Posts: 4,424
    edited October 2010
    if you are going to ask different questions, or not answer the thread as originally intended I would suggest making a different thread regarding the issues.
    Also I have NO idea what your point is with your post. If you are going to grumble about something, etc I would suggest either A. posting it in your own thread you start, or B. Keeping it private via a PM etc as I really don't understand what your saying half the time.
