LSI-15 Limit?
LitoZacky
I was watching IP man 2 the other day with LSI-15 and I turned the AVR up to -5db. I listen to music from -45 to -35 db and I won't watch movies below -10 db from now on. Is there a chance I damaged my speaker ?
Speaker: LSi 15
Pre/Pro: Pioneer VSX-9040
Amp: Emotiva XPA-2
Sub: Seaton Submersive HP
TV: Samsung PN50B550
DAC: soon-to-be EE Minimax Dac Plus
Amp: Emotiva XPA-2
Post edited by LitoZacky on
Are you having problems with them?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
You mean above -10dB? Your hearing will be damaged as I said before.
http://emotivalounge.proboards.com/index.cgi?action=display&board=stupid&thread=13992&page=1#215029
The tweeters and crossover can be damaged first if the amp starts to clip at high levels.
If you run it at sustained high levels, the amp could fail prematurely. The XPA-2 is quite robust, but there are limits.
You can also melt the crossover, as I have done, without damaging the drivers. To the OP, are you experiencing any problems with the speakers?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
No problems I just want to be reassured.Speaker: LSi 15
Amp: Emotiva XPA-2
DAC: soon-to-be EE Minimax Dac Plus -
-5 DB for music is extremely loud and I've never went past -20db. But for movies IMO -5 DB is loud but not as extreme as one would imagine.Speaker: LSi 15
Amp: Emotiva XPA-2
If you are not experiencing troubles, then don't sweat it. Everything should be just fine.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
These numbers on an AVR, -5, +10, etc. mean nothing. They are like Spinal Tap amps going to 11. You need an SPL meter to correlate the sound level to the AVR setting.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
+1
I have recordings that are so quiet that I have to really crank it just to get 75db. -
I agree....They mean nothing. Just a point of reference that I don't even pay attention too. I adjust the volume to the level that I like to hear, not what -db is showing.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
The -x db rating is only for dolby digital anyway - it has no meaning in the analog realm. Turn it up to what you like.
If you start to hear any distortion or if your soundfield starts to collapse - turn it down. If you think you hear distortion but are not sure - turn it down. LSi's can play pretty loud, but they are not anyones definition of a good party speaker.
If quality is your thing, LSi's are all over it. If SPL is what you are going for there, are quite a few options fot that as well, but LSi's are really not your best choice.
