LSI-15 Limit?
LitoZacky
LitoZacky Posts: 115
edited October 2010 in Troubleshooting
I was watching IP man 2 the other day with LSI-15 and I turned the AVR up to -5db. I listen to music from -45 to -35 db and I won't watch movies below -10 db from now on. Is there a chance I damaged my speaker ?
Speaker: LSi 15
Pre/Pro: Pioneer VSX-9040
Amp: Emotiva XPA-2
Sub: Seaton Submersive HP
TV: Samsung PN50B550
DAC: soon-to-be EE Minimax Dac Plus
Post edited by LitoZacky on
    nooshinjohn Posts: 26,064
    edited October 2010
    Are you having problems with them?
    edited October 2010
    xcapri79 wrote: »
    You mean above -10dB? Your hearing will be damaged as I said before.
    http://emotivalounge.proboards.com/index.cgi?action=display&board=stupid&thread=13992&page=1#215029
    The tweeters and crossover can be damaged first if the amp starts to clip at high levels.
    If you run it at sustained high levels, the amp could fail prematurely. The XPA-2 is quite robust, but there are limits.
    You can also melt the crossover, as I have done, without damaging the drivers. To the OP, are you experiencing any problems with the speakers?
  • LitoZacky
    edited October 2010
    No problems I just want to be reassured.
    Speaker: LSi 15
    Amp: Emotiva XPA-2
  • LitoZacky
    edited October 2010
    -5 DB for music is extremely loud and I've never went past -20db. But for movies IMO -5 DB is loud but not as extreme as one would imagine.
    Speaker: LSi 15
    Amp: Emotiva XPA-2
    edited October 2010
    If you are not experiencing troubles, then don't sweat it. Everything should be just fine.
  • BlueFox
    BlueFox Posts: 15,250
    edited October 2010
    These numbers on an AVR, -5, +10, etc. mean nothing. They are like Spinal Tap amps going to 11. You need an SPL meter to correlate the sound level to the AVR setting.
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited October 2010
    BlueFox wrote: »
    +1
    I have recordings that are so quiet that I have to really crank it just to get 75db.
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2010
    BlueFox wrote: »
    I agree....They mean nothing. Just a point of reference that I don't even pay attention too. I adjust the volume to the level that I like to hear, not what -db is showing.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • McLoki
    McLoki Posts: 5,231
    edited October 2010
    The -x db rating is only for dolby digital anyway - it has no meaning in the analog realm. Turn it up to what you like.
    If you start to hear any distortion or if your soundfield starts to collapse - turn it down. If you think you hear distortion but are not sure - turn it down. LSi's can play pretty loud, but they are not anyones definition of a good party speaker.
    If quality is your thing, LSi's are all over it. If SPL is what you are going for there, are quite a few options fot that as well, but LSi's are really not your best choice.
    Michael
