changing out the power switch on adcom 555
sda2mike
simple deal? looks like the replacement just tabs to hold it in..helpful tips anyone?
thanks
mike
thanks
mike
Was the switch you found on-line the correct replacement? if so, then yeah the switch should simply snap in place. You will know right away if its the same size or not. Im assuming the original Adcom switch was not a dual pole switch.
DavidPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
I swapped that switch once. Piece of cake._________________________________________________
SOPAThank God for different opinions. Imagine the world if we all wanted the same woman
