changing out the power switch on adcom 555
sda2mike
sda2mike Posts: 3,131
edited October 2010 in DIY, Mods & Tweaks
simple deal? looks like the replacement just tabs to hold it in..helpful tips anyone?
thanks
mike
  • Knucklehead
    Knucklehead Posts: 3,602
    edited October 2010
    Was the switch you found on-line the correct replacement? if so, then yeah the switch should simply snap in place. You will know right away if its the same size or not. Im assuming the original Adcom switch was not a dual pole switch.
    David
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2010
    I swapped that switch once. Piece of cake.
    SOPA
