Emotiva DAC
124»
    heiney9 Posts: 25,510
    edited October 2010
    Looks can be very deceiving, Steve. But, I'll reserve full judgment until I've actually listened to it. If it sounds similar to the ERCD-1, which I have heard, it should be a decent sounding unit.
  • megasat16
    megasat16 Posts: 3,521
    edited October 2010
    I was one of the participants in the ERC-1 Demo group. It sounds decent if 2D sound is your definition of a decent sound. I think the old Carver CD plays fairly more decent with more depth and imaging and cost me nothing (free).
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    I didn't like the EMO CD player. it was pretty sterile sounding to me, and I agree with the 2D sound.
    Ben
  • megasat16
    edited October 2010
    I read the XDA-1 preview page MillerLiteScott posted. I must say it looks better build than the ERC-1 though. And the buttons layout on the front looks more decent.
    May be EMO is learning a bit and getting more serious about the design. Who knows? Time will tell....
  • steveinaz
    steveinaz Posts: 19,546
    edited October 2010
    heiney9 wrote: »
    Don't get me wrong, even though "it's as good as the Benchmark" I won't be trading "up" anytime soon. :D
    edited October 2010
    megasat16 wrote: »
    That's why I said "decent". I too had an oppotunity to spend an afternoon with the ERC-1. My conclusion, which was posted in the archives, is that it has a lot of competition at it's price point and while it sounded pretty good, I'm sure a few other companies could best it at that price point or less. Said companies being in the business a lot longer, already having a great reputation, etc.
    Slightly sterile and closed in come to mind, not much bass extension. Sounded like the bass note just fell off a cliff after the initial impact.
  • 98Badger
    98Badger Posts: 317
    edited October 2010
    I can't say I'll be checking out this DAC, but for someone who has never used an external DAC and wanted to give it a try, this looks like a relatively cheap way to try one out, especially considering the 30 day return policy.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    megasat16 wrote: »
    IIRC the CDP also incorporates a discrete opamp for the output buffer which is rarity for products at those price points.IMO the analog stage has a strong influence on the final SQ but as I alluded to previously just because it uses a discrete circuit doesn't necessarily make it the equal of a Borbely, Burson,or Bryston DOA.Nor does it automatically make it superior to a premium IC opamp like the LM4562or LME49723 etc.
  • megasat16
    edited October 2010
    Fred, I agree. I think ERC-1 has good potential if they don't use too much cheap junks in there. IMO, the main thing that really hurts to the overall sound quality of the ERC-1 is really cheap junk Chinese capacitors. Otherwise, I think it has a lot of potential to become famous.
    I hope EMO is learning slowly where they can cut corners and where they shouldn't cut corners....IMO, an Aluminum remote does not make it a premium product. If they could just put a good $10 plastics remote and invest better quality materials in the Analog output stages, it could be a winner.
