LSi System Setup
dcmartinpc
dcmartinpc Posts: 844
edited October 2010 in Speakers
OK, I have a complete compliment of LSi speakers. Here is the list:
2 x LSi9
2 x LSi7
1 x LSiC
and on their way to me...
2 x LSIFX
My system is currently setup as a 5.1 system with the LSI9's as fronts, obviously the LSiC is the center, and the LSi7's handle surround duty.
I have 2 questions...
First, I have a Parasound HCA-2205A amp running all of my current LSi's. I have a couple options here... I just purchased an Onkyo TX-NR808 and the amps in it are supposed to be 4 ohm stable so...
1.) Run LSi9's, LSiC, and LSi7's on Parasound and LSiFX's on Onkyo
2.) Run LSi9's, LSiC, and LSiFX's on Parasound and LSi7's on Onkyo
3.) Install Crown XLS 802D (Already Owned) for LSi9's and run everything else on the Parasound
I am leaning towards option 2...
I am currently running a set of Monitor 70's on an XLS 802D and it works quite well. I know it is overkill, but it really makes the Monitor 70's sing and definitely fills out the bottom end.
Second question is, where should I place the LSiFX's and LSi7's.
1.) LSiFX's as Surrounds (Side), and LSi7's as surround back
2.) LSi7's as Surrounds (Side), and LSiFX's as surround back
Here I am a little less decided, but I am leaning towards option 1 here...
Thanks to everyone in advance!
Don
Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
Post edited by dcmartinpc on
  • B Run
    B Run Posts: 1,888
    edited October 2010
    I can't help you with question one, but I definitely agree with going with your LSIFX's for surrounds and Lsi7's for surround back.
  • jimmydep
    jimmydep Posts: 1,305
    edited October 2010
    For question #1 I'd go with #2.
    For question #2 I'd go with #1
  • dcmartinpc
    edited October 2010
    Any other thoughts? I also have an opportunity to pickup another set of LSiFX speakers. Should I be looking at those for both surround channels and move the LSi7's to a 2 channel system or the like?
    Just some thoughts... Any other ideas?
    Don
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited October 2010
    How about a drawing or description of your room, with measurements, seating position, and potential positions for your speakers? Personally, I like my FXi speakers on the sides. I tried them in the back, but didn't care for the effect from the back.
  • dcmartinpc
    edited October 2010
    See.... Right now my "room" is horrible :D I am using one corner of my basement that is roughly 15x20 I would say. But the room is probably 30x40. It is about the worst possible environment, but.... it is what I have until we move.
    Don
  • B Run
    B Run Posts: 1,888
    edited October 2010
    dcmartinpc wrote: »
    Don
    I personally prefer Bipoles for surrounds so I would, plus it's always nice to have a separate 2ch system too.
  • Bernal
    Bernal Posts: 991
    edited October 2010
    For question #2 I'd go with #2
    01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    02) SUNFIRE Grand Signature - Bob Carver's and SUNFIRE Cinema Grand
    03) OPPO BDP-83SE Blu-ray Disc Player w/SACD & DVD-Audio
    04) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    05) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    06) HITACHI P55T501. 55" HD1080 Plasma HDTV
    07) POLKAUDIO LSiC (Center speaker)
    08) POLKAUDIO LSi15 LEFT (Front speaker)
    09) POLKAUDIO LSi15 RIGHT (Front speaker)
    10) POLKAUDIO LSiC Vertically (Surround speaker)
    11) POLKAUDIO LSiC Vertically (Surround speaker)
    12) POLKAUDIO LSif/x LEFT (Surround back speakers)
    13) POLKAUDIO LSif/x RIGHT (Surround back speakers)
    14) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
    http://www.polkaudio.com/forums/showcase/view.php?userid=98096 (Not updated)
  • dcmartinpc
    edited October 2010
    Bernal,
    Could you elaborate a little on this for me. I agree in regards to question 1. But question 2 I am interested in your opinion in a little more detail.
    Thanks!!!
    Don
  • dcmartinpc
    edited October 2010
    Also, I ended up buying another set of FLAWLESS Cherry LSi9's, so I am going to use those in a 2 channel system and leave the LSi7's in the home theater.
    Don
  • dcmartinpc
    edited October 2010
    OK, First off. I tried the XLS 802D on the LSi9's... NOT IMPRESSED. They sounded thin and seemed to almost "flop" around. The amp did not control these well at all. I did try a Crown XTI 2000 I had laying around and it performed much better, but still doesn't seem to keep up with my Parasound...
    So.... In light of that...
    I just picked up a Parasound HCA-1200MKII and a HCA-1500a.
    Here is my new question!
    Which of these amps should I use along side the Parasound 2205a and what place does it have in my system? Should I use it to drive the fronts, surrounds?
    Thanks again for everyone's input!!!
    Also, I have a line on a possible Parasound HCA-2200ii. If I get that, all my amplifier problems are solved :D
    Don
