Balanced IC question
98Badger
98Badger Posts: 317
edited October 2010 in 2 Channel Audio
I've recently upgraded my gear so all the electronics have fully balanced circuitry. As of now, I am using monoprice XLR's. After doing a comparison to Emotiva XLR's (because a friend has them), the monoprice cable seems to produce a harsher sound (cymbals sound tinny) by comparison and causes a bit of listening fatigue. I'm now considering Canare L-4E6S Star Quad's with the Neutrik connectors. I'd appreciate any input from those that have tried these or other options in the same price range.
Post edited by 98Badger on
    Toolfan66 Posts: 18,017
    edited October 2010
    How many hours do you have on the Monoprice?? Maybe give them a few..
    If the Emo still sounds better then use them..
    Also what gear are you running?? Not all gear with XLR's is true balanced..
  • 98Badger
    98Badger Posts: 317
    edited October 2010
    I have about 50 hours on the Monoprice cables. I will give the a little time yet. The Emotiva cables weren't mine, so I'd have to order if I decide to go that route.
    My gear is true balanced. Anthem D1, Wyred4Sound Dac2, and Emotiva XPA-1's.
  • megasat16
    megasat16 Posts: 3,521
    edited October 2010
    Not to meant to offend you or not wanting to a smartie pant but I like to point out that true balanced processing requires from the input to the output (i.e the output section of DAC as a source, both input and output of a preamp, and both input and output of an amp).
    I am not sure D1, W4S, and X1000 has true balanced construction in this manners. Having a balanced connector doesn't ensure true balanced designs.
    You should check with Emotiva whether it is true balanced from input to output stage. It may just have the input summing for balanced circuit and it's not quite the same.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Face
    Face Posts: 14,340
    edited October 2010
    I found Monoprice's interconnects awful.
    I've been using Neotech NEI-3004 with Vampire XLR connectors and also braided Neotech 24ga solid silver chassis wire with Vampire XLR's. The NEI cable is a little warmer with a fuller bottom end and the solid core images slightly better, is more detailed, but the bottom end is more neutral or borderline thin. I have some Neotech copper 20ga solid core cable here I'm going to experiment with next.
  • megasat16
    edited October 2010
    Face wrote: »
    That goes without saying but I found them excellent value for the subs connection (only for sub) in my HT. I won't be using them for the 2 channels rig though.
    Face wrote: »
    You got them from SonicCraft too? I am thinking to DIY some XLR I/C too. I am looking at different wires from SonicCraft now. MIT is boring as hell now. :D
  • cstmar01
    cstmar01 Posts: 4,424
    edited October 2010
    megasat16 wrote: »
    I do not think the XPA-1 has a balanced circuit. From everything I read it is not truly balanced.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2010
    megasat16 wrote: »
    +1
    I learned alot when I did alot of reading and educated myself on true balanced components. The design is completely different :eek:
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • ESavinon
    ESavinon Posts: 3,067
    edited October 2010
    Face wrote: »
    I'm a fan of Fuller Bottom end too mike. :D
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • 98Badger
    98Badger Posts: 317
    edited October 2010
    Thanks for all the input so far. All my gear has fully balanced inputs and outputs, but I'll have to do some more digging to see if the circuits are fully balanced from input to output stages. That being said, I do notice an improvement in resolution and detail using the XLR connections. The monoprice XLR's will definately not be staying in my system.
    I was actually looking at the Vampire stuff a couple of days ago. Maybe I'll find something to hold me over and eventually get around to making my own interconnects.
    edited October 2010
    You can still benifit from XLR's even if the gear is not fully balanced in and out..
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2010
    Don't worry about whether your gear meets some type of ideal design to use XLRs. I prefer the XLRs since they are generally better built, and provide solid connections. Usually you are not going to find XLR connections on low-end gear, and companies providing XLR connections have an interest in their customers hearing good sound coming from their gear.
    Anyway, while perhaps a bit out of your price range I replaced my Kimber Kable Hero XLRs with MIT Shotgun S1.3 XLRs, and it really made a big improvement. The sound stage opened up, and the detail in the music is much clearer. The MITs really made a big improvement. I have had these since the beginning of summer, and I just ordered the matching MIT S1.3 speaker cables to complete the MIT system.
    edited October 2010
    MIT's Rule!!!! hell your in for a treat getting the MIT speaker cables as well...
  • megasat16
    edited October 2010
    BlueFox wrote: »
    I think that statement in general is incorrect. Some really High End gears do not have XLR connections.
    Likewise, a gear featuring XLR type connector does not assure the company has interest for the better sound for their customer.
    All Pro Audio uses XLR connectors too.
  • megasat16
    edited October 2010
    MIT's Rule!!!!
    Yes, the school is! :cool:
  • kawizx9r
    edited October 2010
    megasat16 wrote: »
    Yep, and that's usually because the interconnect runs are fairly long :eek:
    I've yet to hear a fully balanced system, but I've heard a few pieces alone.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • 98Badger
    98Badger Posts: 317
    edited October 2010
    BlueFox wrote: »
    I guess I let myself go off track on the fully balanced vs. true balanced thing. I started reading and it peaked my interest. Looks like gear that is true balanced is above my pay grade but it made for some good reading.
    I'm still trying to decide on a cable budget, so I'm considering all options. The Anthem D1 and W4S Dac are new aquisitions, so my audio fund has pretty much been drained for a while. Like I mentioned earlier, I definately hear improvements using the XLR connections. Previously I was firmly in the "cables don't make a difference" camp. I may start on the affordable end and try some new ones when I have more disposable income. Maybe I'll get lucky and find someone close who can bring some higher quality cables over so I can demo them in my own system. Just curious what gear you are using BlueFox.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited October 2010
    If your interested in an off the shelf reasonable XLR, try Mogami Gold available from The Guitar Center. Not a lot to look at, but a solid, accurate cable for not a lot of bucks.
    I have several pair in rotation in my two channel system.
    Gordon
    Glad to see you took a chance and at least tried various wires. It can be difficult to change our minds on things like this
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • zingo
    zingo Posts: 11,258
    edited October 2010
    98Badger wrote: »
    Canare L-4E6S was the most successful DIY IC cables I've made and it's good stuff. I've been playing around with Cardas stuff lately, but I still use the L-4E6S for internal wiring of electronics, especially where shielding and noise rejection would make a difference. It's a great cable and makes some of the best cost/performance DIY ICs.
  • Face
    Face Posts: 14,340
    edited October 2010
    Jake, what do you think of Cardas' I/C cables? I found them to be rolled off up top. They also turn the tip of my iron a goldish color.
  • Gadabout
    Gadabout Posts: 1,072
    edited October 2010
    My 2 ch rig is being run with all XLR interconnects. Has a mixture of Silver resolution and Analog 2 balanced from Signal Cable. Running all silver interconnects made the system a bit bright. Mixing it up help with the presence and fullness of the sound.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
