Denon DVD-2900 wont play surround music
pmckeealaska
pmckeealaska Posts: 808
edited October 2010 in Troubleshooting
I've had a Denon DVD-2900 Universal player for about 5 years and havent used for much other than high res music. However, I've noticed a problem recently. It seems to have a problem playing surround sound on some DVD-Audio discs. I havent noticed the problem on SACD's either. It plays surround on some DVD-A discs just fine but others it just locks up. Any idea what might be going on? Any suggestions would be greatly appreciated!
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
Post edited by pmckeealaska on
  • george daniel
    george daniel Posts: 12,096
    edited October 2010
    have you tried cleaning the optics?
  • DaveHo
    DaveHo Posts: 3,582
    edited October 2010
    I believe there is a firmware update which fixes this issue. You can download it here: http://stagingna.dev-denon.com/US/Downloads/Pages/Product-Updates.aspx
    -Dave
  • pmckeealaska
    edited October 2010
    Thanks for the suggestions guys! I was thinking of maybe buying a DVD cleaning disc and doing that first. Does this seem like the best way to go?
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
  • HB27
    HB27 Posts: 1,518
    edited October 2010
    I'm not saying it's your issue but I've seen two of them now with bad connections on the RCA's on the rear of the unit.
    Next time you use it you might try moving the cables in the rear and see if they come back in for you.
  • pmckeealaska
    edited October 2010
    There is no download for my model that I can find and the cleaner disc didnt work. Guess it needs to be serviced, which is a bummer cause I really havent used it very much at all, especially recently. I really only use it for playing high res stuff. What a bummer!
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
