Wanna talk/learn about planar speakers?
F1nut
F1nut Posts: 51,701
edited October 2010 in Speakers
A friend of mine, Steve started this and asked if I would post a link here. I checked and was cleared for take off.
http://www.audiocircle.com/index.php?board=177.0
Post edited by F1nut on
  • xj4094dg
    xj4094dg Posts: 1,158
    edited October 2010
    I'm in. I own two pairs of SMGa's that I am thinking of modifying.
    This, I believe is the Peter Gunn xover recommendation?
    > For the SMGa use 50uf as follows:
    > 2 x 22uf obbligato caps
    > 1 x 6uf dynamicap
    > Inductor
    > 1 x 12 gaugue alpha core .78 mh
    Sonicraft offered the following quote:
    2 x 24uF of Sonicap
    Gen 1 with a 2.2uF Mundorf Silver/Oil Supreme.
    -Sonicap G1 24uF ($33.10 each) x4....$132.40
    -S/O 2.2uF ($58.93 each) x2....$117.86
    -AC 12ga/0.82mH (de-wound to 0.78mH) x2....$95.64
    Your total less shipping would be $345.90
    Any thoughts?
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • SteveFord
    SteveFord Posts: 38
    edited October 2010
    Thanks, Jesse!
    As for the SMG mod, I can't answer that one but you could try over at audiocircle.
    I'm sure that someone there has done it.
    That's the great thing about these forums, there's always tons of people who know more than I do (which isn't saying much), ha, ha.
    The bad part about forums is that they make you late for work so I'd better get moving or else it'll be the dreaded Fact Finding in the dungeon.
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2010
    xj4094dg wrote: »
    Any thoughts?
    If you want to do the Peter Gunn mod (HIGHLY recommended), just email him and he will provide you the xover details. He was great help when I did mine.
    And make sure you do replace the MDF with wood, not just upgrade the xover. It doesn't need to look pretty/perfect. The change is breathtaking.
    SOPA
