Placette is (back) in the house
steveinaz
steveinaz Posts: 19,546
edited October 2010 in 2 Channel Audio
Every bit as transparent and linear as I remember. Perfect synergy with my warm Carbon 7's. As compared to the Benchmark in pre mode, bass is tighter, and volume increases are more linear.
I won't make the mistake of selling this one. Wes, with that fancy $3500 Cary amp (which is stellar)--it's time to replace that passive you have with a Placette my man; seroiusly. You got 30 days to return it--try it.
Post edited by steveinaz on
    edited October 2010
    Why Steve...if I didn't know better, your turning into a....gasp...audio snob.:D J/K bro, glad you have the magic back,enjoy.
  • steveinaz
    edited October 2010
    The real motivation was getting off my lazy butt to change volume--but I figured the carbon 7's could use a slight pull to the neutral side. It's working real well.
  • zingo
    zingo Posts: 11,258
    edited October 2010
    Passive preamp are fantastic, with TVC being the best. :D I just love all the passives I've owned and they way they don't screw with your music or change the over all sound of the system. Enjoy the new(old) unit!
  • steveinaz
    edited October 2010
    Placette is packaging a smaller walwart now, where they use to have a power "brick" that sat on the floor---that was a minor disappointment, but not really important in the grand scheme. It's only used to power the level led's and remote receiver.
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited October 2010
    steveinaz wrote: »
    How do you like those 7's? :D
    What did you have before them?
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • steveinaz
    edited October 2010
    Doc
    They are the most enjoyable speaker I have owned in many, many years. Funny thing is, I was never a small speaker fan. I had Energy Connoisseur C-9's. The most notable speakers I've owned in the past were the AR 9Lsi and Infinity RS IIIb; both of those in the '80's.
