Placette is (back) in the house
steveinaz
Every bit as transparent and linear as I remember. Perfect synergy with my warm Carbon 7's. As compared to the Benchmark in pre mode, bass is tighter, and volume increases are more linear.
I won't make the mistake of selling this one. Wes, with that fancy $3500 Cary amp (which is stellar)--it's time to replace that passive you have with a Placette my man; seroiusly. You got 30 days to return it--try it.
Why Steve...if I didn't know better, your turning into a....gasp...audio snob.:D J/K bro, glad you have the magic back,enjoy.HT SYSTEM-
lsi 9's -
The real motivation was getting off my lazy butt to change volume--but I figured the carbon 7's could use a slight pull to the neutral side. It's working real well.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Passive preamp are fantastic, with TVC being the best.
I just love all the passives I've owned and they way they don't screw with your music or change the over all sound of the system. Enjoy the new(old) unit! -
Placette is packaging a smaller walwart now, where they use to have a power "brick" that sat on the floor---that was a minor disappointment, but not really important in the grand scheme. It's only used to power the level led's and remote receiver.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
How do you like those 7's?
What did you have before them?For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
Doc
They are the most enjoyable speaker I have owned in many, many years. Funny thing is, I was never a small speaker fan. I had Energy Connoisseur C-9's. The most notable speakers I've owned in the past were the AR 9Lsi and Infinity RS IIIb; both of those in the '80's.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
