bass shaker hook up
sda2mike
i have a cheepo sony av rcvr i use just for movies...the sw connection on the back is mono! can i hook up 2 bass shakers into the subwoofer wires? would it be series? + to +? ''
thanks
mike
thanks
mike
Post edited by sda2mike on
The SW connection will not power the subs. You need to run the bass shakers with a separate amp and the SW connects to the amp input.SDA SRS 2.3TL's
SDA 2B TL's -
Partsexpress sells some pretty decent Dayton subwoofer amps for around 100 bucks. I had the bass shakers in a HT setup and they worked pretty good.SDA SRS 2.3TL's
SDA 2B TL's -
thanks! im on the bay looking at sw amps;)
Try partsexpress.com as well, they have a good selection of plate amps.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
nclejones reportedSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
nclejones reported
ha! i just ignored him...didn't notice the dubiousness of character:D
