bass shaker hook up
sda2mike
sda2mike Posts: 3,131
i have a cheepo sony av rcvr i use just for movies...the sw connection on the back is mono! can i hook up 2 bass shakers into the subwoofer wires? would it be series? + to +? ''
thanks
mike
  • michaeljhsda2
    michaeljhsda2 Posts: 2,221
    edited October 2010
    The SW connection will not power the subs. You need to run the bass shakers with a separate amp and the SW connects to the amp input.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    edited October 2010
    Partsexpress sells some pretty decent Dayton subwoofer amps for around 100 bucks. I had the bass shakers in a HT setup and they worked pretty good.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • sda2mike
    edited October 2010
    thanks! im on the bay looking at sw amps;)
  • Knucklehead
    Knucklehead Posts: 3,602
    edited October 2010
    Try partsexpress.com as well, they have a good selection of plate amps.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Fongolio
    Fongolio Posts: 3,516
    edited October 2010
    nclejones reported
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • sda2mike
    edited October 2010
    Fongolio wrote: »
    nclejones reported
    ha! i just ignored him...didn't notice the dubiousness of character:D
