ONKYO TX-SR506 with RTI A7
ysheffer
ysheffer Posts: 16
edited October 2010 in Speakers
Hello, appreciate your professional advice.
I'm looking into buying a pair of RTIA7 as fronts to my ONKYO TX-SR506.
Will this combination sound good? Will my receiver be able to push these speakers to their best sound without distortions?
Thank you very much
Yaniv
AV: ONKYO TX-SR506
Front: PEERLESS P503-C
Surround: POLK RTi4
Center: CSi3
SUB: PSW110
DVD: PIONEER DV-310
Post edited by ysheffer on
  • B Run
    B Run Posts: 1,888
    edited October 2010
    This is just my personal opinion but i'd upgrade your receiver first, you won't be hearing them anywhere close to their full potential. However, my first receiver was a tx-sr504 and I had it hooked up to my RT800's and it was ok at normal volume tv watching, but would definitely struggle if I cranked them up and I would get some distortion.
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2010
    Yup. And if the receiver is driving all the speakers at the same time, the A7s won't even get the 75 watts advertised.
    Otherwise, the RTi A7s should be timbre matched to your other speakers - so good choice there :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • ysheffer
    ysheffer Posts: 16
    edited October 2010
    I see,
    Then what's your opinion about the RTIA5? are they a better match to my AVR ?
    AV: ONKYO TX-SR506
    Surround: POLK RTi4
    Center: CSi3
    SUB: PSW110
    DVD: PIONEER DV-310
  • B Run
    B Run Posts: 1,888
    edited October 2010
    ysheffer wrote: »
    I see,
    Honestly you should invest in a better receiver even for the rtia5's. I have the rti8's with a 130wpc yamaha and it's still not enough to hear them to their full potential.
  • bklynNupe
    bklynNupe Posts: 728
    edited October 2010
    You might want to also consider the Rtia5's with a sub over the a7's.
    I think you will also want a avr with pre outs and/or more power. That 506 is not match for ANY of the Rti series in part because of the lack of power imo.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
