ONKYO TX-SR506 with RTI A7
Hello, appreciate your professional advice.
I'm looking into buying a pair of RTIA7 as fronts to my ONKYO TX-SR506.
Will this combination sound good? Will my receiver be able to push these speakers to their best sound without distortions?
Thank you very much
Yaniv
Thank you very much
Yaniv
AV: ONKYO TX-SR506
Front: PEERLESS P503-C
Surround: POLK RTi4
Center: CSi3
SUB: PSW110
DVD: PIONEER DV-310
Surround: POLK RTi4
Center: CSi3
SUB: PSW110
DVD: PIONEER DV-310
Post edited by ysheffer on
This is just my personal opinion but i'd upgrade your receiver first, you won't be hearing them anywhere close to their full potential. However, my first receiver was a tx-sr504 and I had it hooked up to my RT800's and it was ok at normal volume tv watching, but would definitely struggle if I cranked them up and I would get some distortion.
Yup. And if the receiver is driving all the speakers at the same time, the A7s won't even get the 75 watts advertised.
Otherwise, the RTi A7s should be timbre matched to your other speakers - so good choice there
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I see,
Then what's your opinion about the RTIA5? are they a better match to my AVR ?AV: ONKYO TX-SR506
Surround: POLK RTi4
Center: CSi3
SUB: PSW110
DVD: PIONEER DV-310 -
I see,
Honestly you should invest in a better receiver even for the rtia5's. I have the rti8's with a 130wpc yamaha and it's still not enough to hear them to their full potential. -
You might want to also consider the Rtia5's with a sub over the a7's.
I think you will also want a avr with pre outs and/or more power. That 506 is not match for ANY of the Rti series in part because of the lack of power imo.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut
