vibration and microphonics in XO caps
mmadden28
mmadden28 Posts: 4,283
edited September 2010 in DIY, Mods & Tweaks
Is vibration and/or microphonics an issue in internal crossovers?
I have plenty of small, otherwise unusable pieces of Dynamat Extreme available as leftover from Dynamatting my drivers. Would it be worthwhile to put a small piece on any of the caps, inductors or boards? Or would that actually be detrimental?
I noticed either foam tape or is glue in use in a lot of the original boards-I'm assuming that was intended to address the same issue?? or is that just used to secure the parts from flopping around?
Is hot gluing (sp?) components just as good a solution?
Thoughts?
____________________
Pool: Atrium 60's/45's
Post edited by mmadden28 on
  • amulford
    amulford Posts: 5,020
    my thought is you have WAY too much time on your hands...:p
  • mmadden28
    amulford wrote: »
    lol ;)
    Well I'm upgrading my XOs now and figured while I have them out...
  • Face
    Face Posts: 14,340
    In my personal speakers, I mount the components to 3/4" MDF via zip ties and hot glue(sparingly on resistors). Then bolt the MDF boards to the cabinet.
    Dynamat may be ok on caps, but I would keep it away from everything else.
  • skrol
    skrol Posts: 3,437
    I've wondered about this too. It seems like the components are still subject to vibration even with glue and tie-wraps. Why isn't it common practice to mount the XO externally?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • mmadden28
    Face wrote: »
    I'll do that later when I really have some spare time. :o PtP with some nice new foil inductors and higher end caps and resistors.
    What really got me curious about this was mainly the caps. I have a soup can 91µF film cap here, that essentially rings when I wrap my knuckles against it. Its also present in smaller film caps, just not as obvious. So that got me wondering if that can have any negative affect on anything audible.
    I'm sure I'll never know for sure, but really wanted to be sure I didn't add to any issues.
    So I'll continue Hot Gluing as I have been (minus the resistor), and add a small scrap of Dynamat to the caps where possible.
    Thanks Mike
  • mmadden28
    skrol wrote: »
    Stan
    I guess the question is how much of an impact does vibration cause to make it worth doing???. I just read a recent thread on the external XO and believe the general consensus was the hassle of the extra external wires and such was a negative factor.
