Crossover Upgrade Costs?
Outfitter03
Outfitter03 Posts: 563
edited September 2010 in DIY, Mods & Tweaks
I have spent some time recently studying capacitors and crossover upgrades. My question has no right answer, but I would like to hear some feedback.
What do you believe is a good budget for upgrading crossovers?
The crossovers I would like to discuss are for the Monitor 10A and SDA 1C.
These are for minty speakers that will not be sold in the foreseeable future, so recovering expenses is not the concern. More important is doing this once, and doing it right!
The better quality capacitors get expensive very quickly! Is it reasonable for upgrading these older classic speakers to spend 50% of the used value on crossover upgrades? 100%? More?
Are the tweeter crossover circuits the most important for high quality capacitors?
Post edited by Outfitter03 on
    F1nut Posts: 51,771
    You said it, there is no right answer. Spend what you are comfortable with and the entire circuit matters, IMO.
  • TrashyTrucker
    TrashyTrucker Posts: 225
    Outfitter,
    I just took the plunge on the upgrades and glad I did. It sounds amazing! F1nut told me I would be amazed and he was right! (Thanks F1nut BTW!) But Seriously Outfitter back to your question, only YOU can answer that. IMHO... If it is a SDA? Its gonna sound even better upgrading to more moderized parts.
    Good luck and Post pics when and if you do them!
    regards,
    Matt :D
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
  • Vette C6.r
    Vette C6.r Posts: 1,560
    You said it, there is no right answer. Spend what you are comfortable with and the entire curcuit matters, IMO.
    +1. Even on my limited audio budget I spent 1/4 of the speaker price on the capacitors and resistors. Totatly worth it.
    IMO I would do the 1C's first.
    Make sure you change the tweets to the RDO's as well.
    Enjoy
