Playstation 1 Model SCPH-1001 as High quality cd player?
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited September 2010 in Electronics
I am intrigued by this. I have been reading some articles that the playstation one is a great hi fi cd player "model SCPH-1001". Does anyone else know anything about this or run one in there setup?
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
    heiney9 Posts: 25,583
    ...........and SPAM is great lunch meat.
  • kawizx9r
    kawizx9r Posts: 5,150
    Can't believe it's not butter!
    In all honesty though, why bother really?
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • punk-roc
    punk-roc Posts: 1,150
    Stereophile had it listed in their "best of" components issue.. can't remember where it rated exactly.. but they claimed it was pretty darn good...
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • Zitro
    Zitro Posts: 864
    I have heard the same, read reviews of people using it with good results. For the going price of a PS1, can't hurt too much to try, eh?
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • Fongolio
    Fongolio Posts: 3,516
    I've got one of the 1001 models and it's pretty good but my modded Rotel is better. The best model to get is the SCPH-5001. It uses the same DAC but has a better transport. Only thing is it doesn't have the rca outs so you would have to find an AV adapter. Both are really quite nice sounding but won't sound better than a good transport/DAC combo. However they do provide a step up from most universal players.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • bigaudiofanatic
    Interesting I might have to pick one up.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • nedh84
    nedh84 Posts: 143
    That particular model isn't something you buy in stores is it? I gotta check to see if my old PS1 is still around. I think I threw it out when ps2 came around X(
    HT and Music Rig
    Receiver- NAD T765 HD
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds side- Polk Audio Monitor 60
    Sub- Polk Audio PSW505
    Windows 7 Media Center
    T.V.- 40" Sony Bravia LCD 1080P
    Blu-Ray- 80 GB PS3
  • Face
    Face Posts: 14,340
    It's great if you like a rolled off top end and low end.
  • bigaudiofanatic
    Something you can get on ebay for like 40 bucks.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    Don't mean to dump on your parade big guy, but do you really think your getting a "high end" cdp for 40 clams ?
    I bought one of these to settle the so-called debate. The long and the short...yes it rolls off the highs--some of which is a good thing if you're not running very high end gear or have some nice glowingly WARM tubes somewhere in your rig. ALL the CDPs I've heard in the lower range--the one most of us can afford (less than 1 grand)....have some digital glare up high).
    So what does the Sony sound like on mid-fi equipment. Let's say a NAD integrated and some decent Polk vintage bookshelves? Well it ain't a 1000+ player but it holds up against most 500 dollar players well enough. For 20-30 dollars...it's worth that but I don't disagree with tonyb above or Face.
    However...if you're on a BUDGET. Pick one up and listen for yourself. You won't get listening fatigue and you won't hear that AWFULLY 'defined' high end most players in that lower price range have that after 5 minutes sounds like someone running their nails on a chalkboard...the omissions are OK for casual listening--for 20 some bucks?
    cnh
  • bigaudiofanatic
    How does it stack up against my Denon? Which...for some reason is not listed in my rig. Will post that in a bit.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • mantis
    mantis Posts: 17,611
    Face wrote: »
    I heard many good things about the Ps1 player as a CD player. I myself never tried one. Where does it roll off? Like it just cuts the highs and lows and your stuck with a solid midrange?
    At what audio point does this go on? Like 10k? and then 30hz?
    Dan
  • cdn5003
    cdn5003 Posts: 144
    I have one of the ps1's with the RCA outs 1001 I think. It is definitely better than my cheap 5 disk and single disk sony players.
    I am running it with an adcom 535 pre and a carver tfm 25 amp with Rti 10s which are on the bright side for music.
    The sony 5 disk and single disk player are too bright for my setup, I get fatigue pretty quickly if I listen at 85 db or so for more than 20 minutes. The ps1 player rolls off these harsh highs and allows me to really enjoy my Rti 10s for music, this is great because I can't afford an expensive cd player and don't have the room for a dedicated 2 channel system.
    The ps1 cost me less than $20 shipped from ebay. Considering its price compared to the price of the other gear in a stereo setup it is worth a try.
    I would love to try a true high end cd player in my setup to do a proper comparison but that will have to wait for now.
    HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
    2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2
  • avguytx
    avguytx Posts: 1,628
    I have 3 of them in the attic and that seems to be where they've sounded the best to me. :D I don't have any "high end" CD players, per se, but they in no way sounded better than my Denon DCD-1560, DCM-560 changer, Carver TL-3300, SD/A-360 Changer or any other player I have. Plus, they were a complete pain in the **** to work.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • Face
    Face Posts: 14,340
    cdn5003 wrote: »
    You would like Marantz's house sound.
  • Polkie2009
    Polkie2009 Posts: 3,834
    I dug mine out of all the clutter and it's the 5001 series. How much different would a CD sound on this thing compared to playing one on a PS3 slim?
  • Serendipity
    Serendipity Posts: 6,975
    Believe it or not, these are some "sleeper" players. Of course not as good as a dedicated high-end CDP, but they sound decent.
    I also have an Onkyo which sounds great for a low-end player.
    To a large extent, Cost /= Performance. At least not always.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
