mm6501+foam baffle enclosure = ?
abraves4410
abraves4410 Posts: 3
edited September 2010 in Speakers
I have a set of mm6501 components that I am going to be using only above 100hz or so, as I already have a dedicated subwoofer in my car. I've heard a lot of terrible things about these speakers baffles, and have actually tried em once before without any success. However, with that being said, I was wondering what the outcome would be if I made the foam enclosure solid, and slightly larger, by doing some fiberglassing on the outside of the foam( and stretching it out a bit). I'm sure that most of the negative results are from the foam flexing and changing shapes. What im thinking is that making it solid should create a nice enclosure to help out the mids and mid bass, much like a sealed enclosure would do with a sub. If any one has any insight on this, let me know before I waste 15 bucks just to practice my fiberglass skills.
I searched the forum, and although it was kind of mentioned in another post, there was never an answer for it, or anything really similar to it. Thanks in advance guys.
Post edited by abraves4410 on
  • abraves4410
    I was referring to one of these:
    and laying down fiberglass over the back of it(the part inside the door) to essentially create a small, sealed enclosure for the speaker. sorry if that wasnt worded clearly, I was in a rush to finish up before I had to leave for class.
    I tried it once before, but I had issues with the back flexing...I was theorizing that making the enclosure much more rigid would create a much better sound, similar to what i get out my home theater satellites. I would make them a little bit bigger than what they come once i lay them in and door and see where I have room in the door panels...
