Looking under the hood
1252628303142
    VR3 Posts: 29,626
    edited September 2010
    Symphonic Line Klarheit II
  • doctor r
    doctor r Posts: 837
    VAC Standard LE with MM.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • lanchile
    lanchile Posts: 560
    These are my guts!
    Make it simple...Make it better!
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    Here is a classic Moscode 600 hybrid tube solid state amplifier that I worked on. I replaced the coupling caps and critical audio path resistors, installed some new binding posts and RCA inputs. I replaced the power cord with an IEC type socket, re-tubed and set all the bias and DC offset and high voltage adjustments. I also painted the AC transformer and cleaned up all the chassis and circuitry.
    Sounds great!
    Enjoy, Ken
  • megasat16
    megasat16 Posts: 3,521
    Looks neat, Ken! The new caps are a plus!
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • zingo
    zingo Posts: 11,258
    StereoKnight Silverstone Passive Balanced TVC Preamp
  • megasat16
    That's pretty cool passive there, Jake! I really like the way StereoKnights gets their passive done. Good POT, good wire and nice case. I always wanted to try their Magnetic Passive Pre one day.
  • zingo
    zingo Posts: 11,258
    They do make great products with great designs.
  • Face
    Face Posts: 14,340
    Work in progress.
    Drivers are ScanSpeak Air Circ 6620, Accuton C79, and SEAS W22NY. Crossover topology is still TBD. I'd like to give Duelund slopes(transient perfect) a try, but don't believe I'll have enough room inside for all the parts required, so I'll probably use LR 2nd order or something similar to Joseph Audio's infinite slope.
  • megasat16
    Wow! 3stacks of x 3/4" Birch Ply for the front baffle. :D Where's the ****(embly), dude?
    It's empty now. :D
    May be you woke up and thinking this is the DIY thread. :p
  • zingo
    zingo Posts: 11,258
    Face wrote: »
    That is my favorite dome tweeter, and I've heard nothing but good things about Accuton drivers. I can't wait to see how this project turns out.
  • FTGV
    FTGV Posts: 3,650
    My new sub amp.400 watts of Hypex Class D powered by Hypex's 600watt switching supply.This will be replacing a toasted ICEmodule.
    mhardy6647 Posts: 35,372
    Looking good... efficiency would be even higher with the wires hooked up, rather than using the Tesla method :-)
  • FTGV
    FTGV Posts: 3,650
    .. efficiency would be even higher with the wires hooked up....
    I think your probably right,but I'm concerned that by hooking up the switching supply the induced EMI levels will comprimise the low noise performance.:D
    you simply need a Flux Capacitor.
  • FTGV
    FTGV Posts: 3,650
    What the flux?Where do I find one of those?
  • thsmith
    thsmith Posts: 6,082
    My new to me Wright WPA 50-50
    billbillw Posts: 7,956
    Rick88 wrote: »
    My brand new Pioneer Elite DV-79AVi universal disc player that I will be using exclusively for CD playback:
    I see similarities to my new Elite PD-D9 SACD player. I will be posting some photos of that one soon.
    Rick88 wrote: »
    Can't wait to see it!
    OK, Here is my new Pioneer Elite PD-D9-J SACD player. Impressive build quality for the price.
    Before I got this unit, I wasn't sure whether these were gray, or a dull black brushed, but it is actually a gray brushed finish. With reflections, it takes on a silvery look. Top cover is also brushed alu.
    Power supply is impressive in layout, design, and parts. Two large filter caps with a nice dampener ring around it. Twin R-core transformers are in a steel box. The whole power supply is separated from the Upsampling/DAC/Analog section by a steel divider.
    The analog section is nice and simple. From the output of the twin Wolfson DACs, there is one thru hole op amp (which makes it easy to upgrade!) and some decent coupling caps (that are bypassed with a poly). The DAC/Analog section is loaded with OSCON, Nippon, and Rubycon caps. Nice Copper dividers between the analog section and the noisier digital sections of board.
    Overall, I'm very happy with this unit. My only complaint is the lack of track advance buttons on the front face. The remote could be much nicer too, but I'll end up using my harmony.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    My new find for my basement vintage rig,a Yammy CA-800.
    edited October 2010
    CA-800's a nice piece. Try it in Class A (just don't throw the "Class A" switch with the amp operating - it doesn't like that).
    (I've never looked inside, since I bought this one already rehabilitated)
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    I thought you might be familiar with it Mark,yours looks to be mint.I was given this one just today so have not yet lifted the hood.(The matching tuner will be joining it soon).It sounds better than I expected but I will need to take the Deoxit to the switches and replace the power on indicator(LED or bulb?).Any common issues with this model you are aware of?
    edited October 2010
    Vintage Yamaha and vintage Polk Audio go very well together.
    The only issues I know of:
    The aforementioned "class A" switch.
    Dirty function switches.
    Dirty "pre/mail" coupling switch.
    You may find some CA-800 docs at: http://sportsbil.com/yamaha/
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Thanks for the link,the sm may come in handy.As for the Class A switch it seems to be functioning fine but I will heed your warning.I'm assuming when switched to the A position bias is being increased and rail voltages reduced which I can't think doing on the fly would be good.I do find the variable loudness to actually be a useful feature for low level listening.
    I'll be keeping an eye for some vintage monitor series Polks,EPI's or Burhoe acoustics.
  • megasat16
    edited October 2010
    Nice Looking Vintage Yammy! At 10W rms (20W dynamic) in Class A, you could do well with a small bookshelves of moderate sensitivity in the basement.
    I guess the Class A or Normal selection switch can be put in Class A permanently and weld it at that position to avoid any dirty little things inside from shooting smokes. :D
  • Face
    Face Posts: 14,340
    edited October 2010
    FTGV wrote: »
    Or you could just build something else...
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Face wrote: »
    I'm using my RB2/PMC DB1 mini TL clones with it but they aren't exactly vintage.:) For nostalgic reasons I'd like to snag a nice pair of EPI 100's or Burhoe Reds as they were the first real hi fi speakers I was exposed to.
    edited October 2010
    Nothing wrong, of course, with building or buying new but... also nothing wrong with any of the vintage choices he mentioned (IMNSHO, of course) :-)
    FWIW, my "new" speakers were made in 1964... well, the cabinets were made two months ago... but the drivers date to 1964.
    A pair of ads L-710s would be dandy as well; they're really neutral and nonfatiguing, as well as "surprisingly sensitive".
    Just sayin'...
    EDIT: Face, them thingies you're working on are looking good, no doubt about that! No pesky cabinet resonances from them, I'll betcha.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Nothing wrong, of course, with building or buying new but....
    I'm in the process of building a pair as well,but they will have their own dedicated Class D modules.:)
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Another vintage find.Marantz 6300 (circa 1976).
