TSi400 Front Towers
Linkon
Linkon Posts: 9
edited September 2010 in Speakers
Hello,
I just recieved my new TSi400 towers i'm using for fronts yesterday. I do not see in the manual if I shoul set my receiver as "Large" or "Small" for those 2 channels. Does anyone know what it should be? I set them to large for now.
Thanks!
Post edited by Linkon on
  • mudwrx
    mudwrx Posts: 367
    I have TSi400's as well. I believe the setting depends on the AVR and if you have a sub or not. In my case I have a PSW505 and set the towers to large since my AVR said if they are towers, set to large. Sounds great, no complaints.
    Good luck.
  • Linkon
    Linkon Posts: 9
    mudwrx,
    Thank you. I ordered a PSW505 last week and it is scheduled for delivery today!
    I have a Denon AVR-788, I'll flip through the manual again but its good to know that you have the same speakers and your avr is set to large.
    Thanks!
    I'm dying to find out how everything sounds with the sub! I also have a CS20 center channel so hopefully I will be happy with it all.
  • mudwrx
    mudwrx Posts: 367
    Linkon wrote: »
    mudwrx,
    Thanks!
    I think we have a similar setup. I also have the CS20 center. I have FXiA4's for surrounds. You're going to love the PSW505, make sure you give it some good movies to chew on and you'll hear what it can do.
  • PrazVT
    PrazVT Posts: 1,607
    I think the "large" and "small" settings are inaccurate labels. From what I understand, it's more about how low the speakers will go frequency-wise as opposed to physical driver size. I think the TSi 400s will go down to 44hz and the CS20 will go down to 58hz. As such, my avr sees the RTi A7s as large, the CS20 as small, and the monitor 50s as small. So I run the A7s full band and set the PSW505 crossover to 60Hz. I think 80Hz is the THX standard but in my setup, 60Hz seems to blend better.
    I agree you'll love the PSW505 :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Linkon
    Linkon Posts: 9
    mudwrx wrote: »
    Do you have any recommendations as far as Blu-Ray moves go? I dont watch many movies but I'd like to go pick something up after work today.
  • Linkon
    Linkon Posts: 9
    PrazVT wrote: »
    PrazVT, thanks for the info. DO you have any experience using Audyssey? My receiver has it - I might just run that and let it complete the setup for me, not sure yet.
  • PrazVT
    PrazVT Posts: 1,607
    @ Linkon
    Yes, I have Audyssey MultEQ XT on my Denon. I usually run it using the recommended 6 different placements.
    I find that for movies / TV, it's very effective at room correction.
    For 2 ch music, I usually bypass Audyssey because it makes my front towers sound a little weak and tinny.
    The only real manual tweak that's required is adjusting the sub gain - Audyssey tends to set it a little low.
    I would say try it and watch a movie and see if you like it.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • mudwrx
    mudwrx Posts: 367
    Linkon wrote: »
    There has been some posts on this, here is one link:
    http://www.polkaudio.com/forums/showthread.php?t=105908
    From what I hear (no pun intended), War of the Worlds seems to be one of the best movies to show off a sub.
  • PrazVT
    PrazVT Posts: 1,607
    The Hurt Locker is another good movie to demo on as well - lot of explosions / gunfire through the surrounds
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • Linkon
    Linkon Posts: 9
    PrazVT wrote: »
    @ Linkon
    Praz - thanks again.
    I just got all of my speakers and sub hooked up and the highs sounded a little flat so I ran Audyssey. I agree - it set the sub a little low and it made the highs a little too bright. But overall - holy crap!!!! Sounds great!!! That sub shakes my house!! Maybe I should just let these speakers break in for a few days before I start trying to tweak things too much but its hard not too :D
  • Linkon
    Linkon Posts: 9
    mudwrx wrote: »
    mudwrx - thanks for the link, i'll check it out.
  • 08op
    08op Posts: 18
    hey all i also have the 400's as fronts but cs10 center with a klipsch rw12 sub, if i set front as large i loose bass from sub,if i set to small i get more from the sub. does anyone else's do that?
  • Linkon
    Linkon Posts: 9
    08op wrote: »
    Mine does not do that
  • troy_b.
    troy_b. Posts: 29
    I have about the same set up. TSI 400's for fronts, CS20 Center, Monitor 30 surrounds, PSW505 and Velodyne Impact ten for subs. I have the fronts and center set to small as well as my surrounds of course. My crossover is set to 80. Sounds good to me with movies and music. Good luck.
    Troy_B.
  • spock 2054
    spock 2054 Posts: 163
    "hey all i also have the 400's as fronts but cs10 center with a klipsch rw12 sub, if i set front as large i loose bass from sub,if i set to small i get more from the sub. does anyone else's do that?"
    Low frequency effects are not being directed to your sub if your speakers are set to large. Link below...
    "Redirecting the bass to the subwoofer relieves the receiver amplifiers from having to work on reproducing the low frequencies and this greatly improves the headroom. If you happen to be using Audyssey MultEQ for room correction, you will achieve much better low frequency performance because the MultEQ subwoofer filters have 8x higher resolution than the filters in the other channels.
    Here is a better rule: All speakers are Small. In today’s complicated AVR lingo that just means: If you have a subwoofer you should always turn bass management on. Always. Even if your receiver clings to the past and automatically sets your speakers to Large."
    http://www.audyssey.com/blog/2009/05/small-vs-large/
    I found that audyssey set ALL of my speakers for full band (Large). I found, for my room, these settings were optimal:
    Front 50Hz
    Center 60Hz
    Surround 60Hz
    Surround Back 100Hz
    Sub 120Hz
    polk monitor 70's
    center - polk monitor cs2
    surround - polk monitor 60's
    surround back - jbl e10
    sub - velodyne dps 12
    sub - polk psw110
    avr/pre-amp - onkyo tx-nr809
    amp - adcom gfa-5500
    amp - carver av405
    display - sharp lc70le847u
    tv - silicon dust hd homern
    blu-ray - oppo bdp-103
    hd dvd- toshiba hd xa2
    control - logitech harmony one
    turntable - technics sl1500 mkII
  • PrazVT
    PrazVT Posts: 1,607
    I think that depends on your AVR - I know my Yamaha and my Denon both have "LFE + Front (or Main)" settings that allow the sub to operate if all the speakers are set to full band (Large).
    Otherwise for the TSi 400s and Monitor 70s, I'd agree it's probably better to set 'em all to 'small'.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • Linkon
    Linkon Posts: 9
    PrazVT wrote: »
    My Denon has 2 options "LFE" or "LFE+Main". I switch between the 2 options when going from movies to music. the "LFE+Main" definitley sounds better with most music but sometimes it seems to send too much bass to the sub during certain scenes in certain movies so I switch to LFE. I wish there was an easier way to switch between the 2 options :D
  • spock 2054
    Linkon wrote: »
    Depends on your main speakers. What are they? They should be set to small. Snip and link:
    http://www.avsforum.com/avs-vb/showthread.php?t=999729
    polk monitor 70's
    sub - polk psw110
    amp - carver av405
  • Linkon
    Linkon Posts: 9
    I think audyssey changed them to small when I ran it but I will double check. Thanks for that link, that was very helpful!
