DIY Sail panel mod for tweeters
kawizx9rkawizx9r Posts: 5,179
edited March 2011 in Custom Fabrication
Well as some of you know, I installed some Alpine components in my vehicle after being sick of the 'premium' factory stereo in my PT Cruiser GT.
Disconnected the rears altogether, reinstalled my Kenwood stereo amp and ran new wire from the door panels and out to the trunk so the components are now powered by an external amp. Sounds much better than it did the 1-2 days I had the speakers installed running off my HU.
I wanted to bring the tweeters up high, and I was NOT going to install them up in the dash where the factory tweeters were (they would've been aimed upwards torwards the glass) so I thought I'd install them in my sail panels. Unfortunately, the sail panels had a slight curve so they didn't sit flush. So here's what I did instead!
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
heiney9 wrote: »
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
  • kawizx9rkawizx9r Posts: 5,179
    edited September 2010
    You'll see here I used a hole-saw to cut out holes for the tweeters. Since they didn't sit flush in the panels, I thought I'd do some minor custom work myself. Here's one sanded down next to the other with only a hole drilled through it.
    Here, I played around a bit with angling the tweeter mount. Soon as I got the angle I wanted from where I'd be sitting, I glued a popsicle stick in place.
    Here are both panels with tweeter mounts glued on.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Next comes the bondo!
    After the very first application of bondo, sanded down.
    Both sanded down and carved somewhat to the shape I want.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    This is when I start using the automotive glaze to fill in the small imperfections. You'll notice it's darker than bondo, and it's much easier to work with.
    First coat of primer applied!
    Sanded down smooth for some more automotive glaze and another coat of primer.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    I want to say this is the 6th coat of primer. It was primer+sand+automotive glaze+sand then primer again.
    Very first coat of paint. Wanted to see how the finish would come out. It was too glossy for me and stuck out like a sore thumb in my vehicle.
    This next one is after 2 coats of paint and 2-3 layers of paint (done from afar) to create a 'textured' finish. I wanted the sail panels to blend back in as much as possible with the rest of the interior.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Installed back in! Still need to play with the tweeter swivel, but I'm not too worried about it just yet because I'm looking to upgrade my HU.
    Hope you all enjoy the pics!
    Btw, the imperfections look worse than they really are! Took these with my digital camera with the Macro setting ON so everything shows up :eek:
    -Freddy
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Oh and here's the HU that's soon to be replaced. Looking at getting the Kenwood Excelon X794.
    And the mess I have in the rear.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Toolfan66Toolfan66 Posts: 14,249
    Nice Work!! I take that back I should say Beautiful Work!!!
    Enjoy!!!!
    Enjoy!!!!
    Thanks Larry!
    Looking back at that pic, the tweeter is turned way in lol I'll fix it later.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Lil update, the speakers are sounding really good now with the tweeter raised up closer to ear level and because they're breaking in :)
    Can't wait to replace my HU!
    Will upgrade my sub later, and use the JL Audio amp for the components (which may be switched out for some Polk MM's). I'm wanting some more midrange, maybe use an 8" sub as a mid-bass module?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • mole'mole' Posts: 3,160
    this is what you were doing last week when i text ya? looks awesome man.
    mole'
    mole' wrote: »
    Heh when I told ya I was a bit busy? Yep!
    Took a hell of a time sanding by hand! Used a dremel tool to partially carve away the excess bondo but it sanded off way too quick so I stuck with hand-sanding it.
    And thanks :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    kawizx9r wrote: »
    And thanks :D
    ill get that WGA shipped out for ya today. have some other things to ship out aswell. i have a big turbo kit that would wake your Pt/Gt up. i did almost 450hp with it on pump gas. :evilgrin:
    mole'
    mole' wrote: »
    Geez, but that'll cost a hefty amount haha.
    On the other thread, you'll see pics of when I swapped out the wires+plugs as well as my straight pipe.
    Next is upper+lower intake manifold swap, diablo sport predator tuner, the wga you're sending out :D, bigger fuel injectors, magnaflow catback exhaust, and whatever else comes my way.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    kawizx9r wrote: »
    what size injectors you looking for?
    i have a set of 750cc and 1680cc here im not using anymore.
    mole'
    mole' wrote: »
    Whatever injectors that are recommended when one gets stage 1. Although since I won't be getting S1 the tuner will bring it up to those levels so I'll need that.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • mdaudioguymdaudioguy Posts: 5,082
    Hey man, nice work! :)
    mdaudioguy wrote: »
    Thanks!
    Half tempted to make some kick-panels for my 6 1/2"s I've got in the door...hmmm
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    kawizx9r wrote: »
    if you plan on keeping your stock turbo, these are WAY over kill for you. even if you used 100% e-85. Mopar stage 2 injectors would be the most you would ever need.
    mole'
    kawizx9r wrote: »
    Thanks!
    check these out
    http://www.carbonbydesign.com/proddetail.asp?prod=srt4_speaker_pods
    shop is located in SD. i got all of my Carbon Fiber stuff from them.
    mole'
    kawizx9r wrote: »
    Thanks!
    I say go for it. What have you got to lose? Looks like a fun project, and you're pretty good with that Bondo! I'm sure you could beat $299...
    mdaudioguy wrote: »
    ya im sure he could. just showing him the pics of what they make.
    mole'
    mdaudioguy wrote: »
    Heh thanks, but now I think I'll have to redo these sail panels or mod them a bit.
    Just bought some SR6500's from the garage sale on here, so now I'll need some new tweeters. I plan on ordering some Vifa ring radiator tweets, but don't know if they'll fit properly in my current panels and if it'll be an ideal location for them.
    mole' wrote: »
    Checked out the site, they've got some nice looking stuff! It's actual carbon fiber as opposed to the fiberglass stuff that's given that carbon fiber look which is pretty cool but I might just have to make some myself anyway.
    We'll see! Though if I do, I'll be sure to post a separate thread on that as well ;)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Ordered these - https://www.madisound.com/store/product_info.php?cPath=45_229_427&products_id=1679
    Can't wait now!
    Depending how everything comes out, I might rethink the kicker panels.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    kawizx9r wrote: »
    ya they make REALLY nice stuff. it is $$$ tho. was trying to give ya an idea dfor your kick panels. all of their stuff is real CF. they are a vendor on my site.
    mole'
    mole' wrote: »
    Got any custom panels/molds done to your SRT4's interior?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Well, I'm thinking that since I don't want to completely redo the sail panels that I'd just drop in the Vifa's (after carving away a bit at the Alpine tweeter mount). Only thing is, the tweeter looks a bit big....maybe that's just cause I'm used to the Alpine's smaller footprint.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • DSkipDSkip Posts: 16,114
    edited October 2010
    How goes the install? Any updates?
  • disneyjoe7disneyjoe7 Posts: 11,520
    edited October 2010
    Nice work.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    edited October 2010
    DSkip wrote: »
    Got it all installed the 30th :)
    Need to clean up the slight extra wiring I've got going under the seat because that's where I put each crossover.
    They sound great, though the tweeters need to break-in some. So much detail in these speakers, remind me alot of my LSi's!
    disneyjoe7 wrote: »
    Nice work.
    Thanks!
    I'm going to end up redoing the panels though. The Vifa's pretty much dropped in and with a quarter of a turn, they're in there nice and tight however the angle is not ideal. When I decide to tackle the job all over again I'll do so, in the meantime they still sound pretty good to me :D
    Oh and just for the hell of it since this thread got brought up, figured I'd add the updated pics on here as well of my HU I replaced as well as the SR's that replaced the Alpines.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    edited October 2010
    HU after it came in from Crutchfield
    Installed
    SR6500's when they came in
    SR woofer next to Alpine Type S woofer
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
Howdy, Stranger!
