DIY Sail panel mod for tweeters
Well as some of you know, I installed some Alpine components in my vehicle after being sick of the 'premium' factory stereo in my PT Cruiser GT.
Disconnected the rears altogether, reinstalled my Kenwood stereo amp and ran new wire from the door panels and out to the trunk so the components are now powered by an external amp. Sounds much better than it did the 1-2 days I had the speakers installed running off my HU.
I wanted to bring the tweeters up high, and I was NOT going to install them up in the dash where the factory tweeters were (they would've been aimed upwards torwards the glass) so I thought I'd install them in my sail panels. Unfortunately, the sail panels had a slight curve so they didn't sit flush. So here's what I did instead!
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
Here, I played around a bit with angling the tweeter mount. Soon as I got the angle I wanted from where I'd be sitting, I glued a popsicle stick in place.
Here are both panels with tweeter mounts glued on.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
After the very first application of bondo, sanded down.
Both sanded down and carved somewhat to the shape I want.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
First coat of primer applied!
Sanded down smooth for some more automotive glaze and another coat of primer.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Very first coat of paint. Wanted to see how the finish would come out. It was too glossy for me and stuck out like a sore thumb in my vehicle.
This next one is after 2 coats of paint and 2-3 layers of paint (done from afar) to create a 'textured' finish. I wanted the sail panels to blend back in as much as possible with the rest of the interior.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Hope you all enjoy the pics!
Btw, the imperfections look worse than they really are! Took these with my digital camera with the Macro setting ON so everything shows up :eek:
-Freddy
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
And the mess I have in the rear.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Enjoy!!!!
Thanks Larry!
Looking back at that pic, the tweeter is turned way in lol I'll fix it later.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Can't wait to replace my HU!
Will upgrade my sub later, and use the JL Audio amp for the components (which may be switched out for some Polk MM's). I'm wanting some more midrange, maybe use an 8" sub as a mid-bass module?
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Heh when I told ya I was a bit busy? Yep!
Took a hell of a time sanding by hand! Used a dremel tool to partially carve away the excess bondo but it sanded off way too quick so I stuck with hand-sanding it.
And thanks
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
ill get that WGA shipped out for ya today. have some other things to ship out aswell. i have a big turbo kit that would wake your Pt/Gt up. i did almost 450hp with it on pump gas. :evilgrin:
Geez, but that'll cost a hefty amount haha.
On the other thread, you'll see pics of when I swapped out the wires+plugs as well as my straight pipe.
Next is upper+lower intake manifold swap, diablo sport predator tuner, the wga you're sending out
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
what size injectors you looking for?
i have a set of 750cc and 1680cc here im not using anymore.
Whatever injectors that are recommended when one gets stage 1. Although since I won't be getting S1 the tuner will bring it up to those levels so I'll need that.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Thanks!
Half tempted to make some kick-panels for my 6 1/2"s I've got in the door...hmmm
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
if you plan on keeping your stock turbo, these are WAY over kill for you. even if you used 100% e-85. Mopar stage 2 injectors would be the most you would ever need.
check these out
http://www.carbonbydesign.com/proddetail.asp?prod=srt4_speaker_pods
shop is located in SD. i got all of my Carbon Fiber stuff from them.
I say go for it. What have you got to lose? Looks like a fun project, and you're pretty good with that Bondo! I'm sure you could beat $299...
ya im sure he could. just showing him the pics of what they make.
Heh thanks, but now I think I'll have to redo these sail panels or mod them a bit.
Just bought some SR6500's from the garage sale on here, so now I'll need some new tweeters. I plan on ordering some Vifa ring radiator tweets, but don't know if they'll fit properly in my current panels and if it'll be an ideal location for them.
Checked out the site, they've got some nice looking stuff! It's actual carbon fiber as opposed to the fiberglass stuff that's given that carbon fiber look which is pretty cool but I might just have to make some myself anyway.
We'll see! Though if I do, I'll be sure to post a separate thread on that as well
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Can't wait now!
Depending how everything comes out, I might rethink the kicker panels.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
ya they make REALLY nice stuff. it is $$$ tho. was trying to give ya an idea dfor your kick panels. all of their stuff is real CF. they are a vendor on my site.
Got any custom panels/molds done to your SRT4's interior?
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Got it all installed the 30th
Need to clean up the slight extra wiring I've got going under the seat because that's where I put each crossover.
They sound great, though the tweeters need to break-in some. So much detail in these speakers, remind me alot of my LSi's!
Thanks!
I'm going to end up redoing the panels though. The Vifa's pretty much dropped in and with a quarter of a turn, they're in there nice and tight however the angle is not ideal. When I decide to tackle the job all over again I'll do so, in the meantime they still sound pretty good to me
Oh and just for the hell of it since this thread got brought up, figured I'd add the updated pics on here as well of my HU I replaced as well as the SR's that replaced the Alpines.
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Installed
SR6500's when they came in
SR woofer next to Alpine Type S woofer
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
That is gonna be a sweet sounding rig in your car for sure! Thanks for showing us all the pics! BTW that HU is awesome too! You are gonna love it.
regards,
Matt
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
