amp questions
actually.... now that i think of it i still do have another question. i didnt plan on running an amp as powerful as the brutus like im going to run... what gauge wire should i run with that? and what size of fuse up by the battery?-Matt
and also.. i got to thinking about it and.... well what would be better to get for my 1996 ford escort.. polk db series 5 X 7s and polk db series 5.25s, or jbl component systems for both 5X7s and 5.25s? i know the polk speakers are good, but ive never heard anything by jbl.. so im not sure how good jbl is...-Matt
how many amps are you going to have, or if you think theres even a slight chance of upgrade, how many amps do you think youll have?
what JBL speakers?
JBL has really cheap speakers(price) for beginners, i like em, but their higher end stuff isnt nothing to write home about
-Cody -
i dunno how many amps :-\.. and they are the i believe go component systems.. something like that-Matt
for the burtus i would use a minimum of 4awg for the power and ground....it also depends on the length
imo...i would just use a run of 1/0 back to the trunk...that'll more than likely support anything you do on the futurePost ****
2003 MECA M2/MR2/DB1 IL State Record Holder/Champion
CarAudioForum
SoundIllusionsNetwork
CarAudioTalk -
like the others said, 4ga will run that amp fine, but if you want any headroom for future upgrades you'll want to run 2ga or 1/0 ga to a distro block and then take it to a short 4ga run to the amp and then groundHemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
well my first question still hasent been answered :-\.. which would be better for my 1996 ford escort..jbl component systems or polk db series speakers? jbl component systems: http://www.sounddomain.com/shop/item.pl?sku=JBLGTO8606C&vq_id=none and http://www.sounddomain.com/shop/item.pl?sku=JBLGTO506C&vq_id=none
or polk db series speakers:
http://www.sounddomain.com/shop/item.pl?sku=POLDB570&vq_id=none
and
http://www.sounddomain.com/shop/item.pl?sku=POLDB525&vq_id=none-Matt -
I'd take the polks hands down. and here's the reasons...
Both polks have a higher sensitivity rating (they'll play louder for the power) and a larger frequency range (JBL 5x7's play a little lower but it's unnecissary) than their JBL counterparts.
the JBL's look to have a paper cone, either way it doesn't look like it's one of the better cone materials whereas the polymer/mica composite cone from the polks is a good material for speaker cones. much better than treated paper imo, which is what it looks like JBL is using, and since they don't state anywhere that i could find that it's a higher grade material i'm going to assume that i'm right.
Tweeter: personally i greatly prefer the acoustic detail provided by a silk dome tweeter to any other style of tweeter i'v ever heard. others may disagree with me on this but it's the style that's most pleasing to my ears.
I don't trust the JBL's because of the lack of info they provide, no detail on VC's, tensel, spider etc. not even on their website or in the manual for the speaker. also very little detail on the x-over.
If it were my money i wouldn't hesitate to get the DB's over the JBL's.Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax. -
alright thanks alot man. ill go with the db's. id never heard anything by jbl other than subs.. their subs are descent so i just had to check. looks like its dbs for me
-Matt -
Couple of thoughts, keep in mind, I have less experience then most of the guys here though....
Alarms: Crutchfield sells the CrimeGuard brand, which is an excellent alarm with a life time warranty. I have an Excalibur Gold which is made by the same company. Not sure if anybody out your way sells or installs CrimeGuard but check it out. Also have had very good experience with Clifford alarms, very high quality. Tweeter sells and installs Clifford.
Speakers: Be sure you listen to speakers before you buy them. I was all set to buy the polk db 690's then changed my mind when I heard them and went with the EX369's. The db's have a very hollow sound to me, not very brilliant, at least the 690 3ways did, didn't hear the 5x7's. Several people have told me that they perfer the EXIII series speakers to the db's, and the EXIII's can be found for pretty good prices since they are being discontinued. I was able to hear the EXIII's and thought they were awesome, very full rich sound, but not harsh.
And that's my two cents.......whatever you do make sure you listen to speakers before you buy them.
Kevin -
sorry guys, i havent been on in awhile, so i havent looked at the tips on the alarm and stuff. thanks for the alarm tip site cody :-p, i think ill go by those tips. and on the speakers.. i went out and got myself a nice little christmas present
i got me an amp just to use for now.. its bazooka.. its pushing my subs pretty good, ill eventually upgrade and get the brutus.. thatll be a month or two. and the polk db speakers sound awesome! i love them. ill get the pioneer head unit soon too... as soon as i decide to get up off my lazy **** and go check out the audio stores and see if one of em is selling that one :-\ if not.. i guess ill get it online. im also gonna go stop by us tech sometime in the next week.. they sell viper alarms there so im gonna check on those, if i find one that i like, ill probably buy it, i dont want to spend 1500 bucks or more and then just get it stolen by a pathetic loser that cant afford to buy his own. :-D -Matt -
sounds like a plan
and if you go in the viper place, asking questions about the alarm with confidence like you know what youre talking about(Even if you dont really know what youre talking about...lol)
theyre less likely to try to screw you
remember, sensitivity isnt the greatest thing about an alarm
i mean, if your alarm is half way decent, and someone tries to smash the glass on your window, its going to go off
the best alarms are the ones that cant get bypassed some how by a thief who knows his ****
-Cody -
alright, sounds like a plan... either that or i can just kick his **** and steal the thing... that one always works too. but yea.. ill try acting like i know what im talking about... even though i know jack lol. ill try my best to find a good one.. even if they smash the windows i want it to go off.... i dont want one of those dumb ones that ony goes off if they open the door.. those ones suck :-\-Matt
