Svs Placement
racer4551
racer4551 Posts: 373
I know this is probably a hard question to answer but i am trying to determine a location for 20-39pc+ sub, i am limited on placement so was wondering if it would hurt sub output to locate about 3ft out and 1ft away from corner and wall,if you look at my showcase pics i would like to place in one of the current sub locations. Or would it be better to place directly in corner?
*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
Post edited by racer4551 on
  • pjdami
    pjdami Posts: 1,894
    edited December 2003
    Racer,
    If you have a Radio Shack decibel meter you can go to this website:
    http://beyond_gomer.tripod.com/
    and burn the 1/12 octave test tones to a cd. Then do a sweep test (like I did on another thread here today) and plot the results. I have a spreadsheet that I set up that will do all the correction factors necessary for the RS meter.
    Using the plots and your ears you can then determine what will be best for you. The corner loading will give you some boost in dbs at certain frequencies but you might not need it.
    At least this is a starting point that I would use.
    PJ
