Mortite or MD Cord Weatherstrip
thejck
thejck Posts: 849
edited October 2010 in DIY, Mods & Tweaks
I went to Home Depot today and could not find Mortite. They had this stuff called MD Cord Weatherstip. It looks like mortite but maybe is a little grayer that the pictures posted here. The box is purple.
Is this the same stuff or should I go back out and look for mortite?
Post edited by thejck on
  • Ricardo
    Ricardo Posts: 10,634
    edited September 2010
    I would not change the original gasket material. But that's just my opinion.
    SOPA
    Toolfan66 Posts: 18,164
    It works the same. I have used it..
  • kawizx9r
    kawizx9r Posts: 5,150
    thejck wrote: »
    I've used it too and it works great.
    If you don't plan on taking your speakers out anymore, go for it but if you do it might be a PITA depending how much you put on.
    You could also use this stuff -
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-542
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-540
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    heiney9 Posts: 25,492
    MD works just the same and I highly recommend it over the very aged gaskets. Try to get it flat before tightening the screws and do screw everything back together carefully and try to tighten the screws in a criss-cross pattern.
    See post starting at #171
    http://www.polkaudio.com/forums/showthread.php?t=51420&highlight=upgrade&page=6
  • Ricardo
    heiney9 wrote: »
    Oh, I agree on that, and that's why I said "original gasket material". If they are worn out, cracked, etc, you can use new of the same type of gasket material. I really don't think you'd get that much of a better seal using mortite, and I would definitely avoid the mess.
    SOPA
    Ricardo wrote: »
    Ricardo, have you tried it? It's not messy at all. I think it does a great job, I haven't compared it to "new" original gaskets but I'm more than happy with the results and if Matt and Raife say it works, then I'm confident it's worthwhile :).
  • Ricardo
    Brock, I have not tried it, and I don't think I will. Hard to believe there would be an audible difference. Of course it wouldn't be the first time I've been wrong.
    SOPA
  • thejck
    thejck Posts: 849
    It seems like there are 2 sides of the fence with doing the mortite. I think I am going to go ahead and give it a shot and save my rings for the future in case I feel like I want to try it the other way around.
    I am also doing Larrys rings btw.
    I saw where Larry suggested applying polyurethane on the baffles to prevent the mortite ruining the wood. I will give that a shot since I have extra poly urethane lying around.
    Has anyone experimented with coating the entire inside of the cabinet with it to prevent the fiberboard from eventually breaking down?
  • hearingimpared
    hearingimpared Posts: 21,136
    Ricardo wrote: »
    Agreed! Unless the gasket is warped or disintegrating. I've only used a sealer on my PRs and any MWs where the original gasket is as described above. Even if the original gasket is torn, you can still use it with fine results.
    The only way it will break down is if you get it wet. Look how good it looks in the cabinet 20 years later..
  • hearingimpared
    kawizx9r wrote: »
    Nooooooo!!! Not to step on your toes but I've tried both thicknesses and they DO NOT couple the drivers to the cabinet plus when I was using it, it was so thick that I couldn't get the allen head screw to make contact with the socket thread and it ended up pushing the socket out of the back of the bezel which was a real pain in that arse to get back in.
  • iskandam
    iskandam Posts: 704
    I Mortited my Forte IIs and the results are well worth the time and hassle. I will do it on every single speaker I have now
  • kawizx9r
    Ouch, well good thing you cleared that up!
    I was aware they had a replacement but wasn't sure how thick it was since I've never used it.
    To the OP, don't use it and just stick with Mortite then lol :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • hearingimpared
    kawizx9r wrote: »
    Or this;
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=269-300%20%20%20%20%20%20%20%20&FTR=speaker%20sealing%20caulk&CFID=32807426&CFTOKEN=27943747
    It's what I use in lieu of Mortite.
  • kawizx9r
    Yeah I saw that too.
    Since you mentioned it, I went back and read an old thread Jesse posted and he said the thickness of the original gasket is a mere 1/64". The stuff I posted above comes in 1/4" and 1/8" :eek:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • hearingimpared
    kawizx9r wrote: »
    LOL!!! Unfortunately it was until after my struggle with that crap and the socket being pushed out that I talked to Jesse and he told me if the gaskets are in good shape, I'm good to go.
    I gotta tell ya, this fat boy, when working on my 1.2TLs, was sweating my ballinis off.
    F1nut Posts: 51,954
    Neither.
  • hearingimpared
    Neither.
    Man, you talk too much!:eek::p but when you're right, YOU ARE right!
  • thejck
    thejck Posts: 849
    Ok so now I am confused. Mortite is not a good idea? I have read F1's thread about using the mortite. And I have read DK's thread about the mortite...and I dont really know what to think now. I thought hearingimpared had put it on his speakers as well..
    What can I expect to gain/loose with mortite?
    Is there a recommendation on replacement gaskets if your's are bad instead of mortite?
  • hearingimpared
    thejck wrote: »
    No, no, no Bro, that just Jesse and my experience. There are many, many here who've used the Mortite with great success. So we're just giving you some alternatives. As a matter of fact when Matt Polk and company started out they couldn't afford to have the gaskets made and used Mortite on their products until the could afford the gaskets. So rest easy.:)
    thejck wrote: »
    Just do the mortite/md. It certainly won't be any worse. Just make sure you flatten it a bit before starting to tighten the screws and when tightening just be careful and be sure to tighten evenly. I used it and it made a subtle but positive difference.
    Plus if the designer of the speaker recommends it, it can't be all that bad. If you don;t like it, it can easily be removed and you can then try and source original gasket material.
    Really, this is not worth losing sleep over or does it need a long gestation period. It's simple, easy, cheap and effective.
    P.s. Here's a primer
    http://www.polkaudio.com/forums/showpost.php?p=1307275&postcount=171
    http://www.polkaudio.com/forums/showpost.php?p=1309089&postcount=172
    http://www.polkaudio.com/forums/showpost.php?p=1313505&postcount=173
  • Ricardo
    Wow Brock. Who would've thought that mortite required break in!!
    :p
    SOPA
    Ricardo wrote: »
    :p
    It did! Everything in this hobby has a break in period. The molecules in the Mortite are not easily excitable so it takes a few days to get them excited to the point where their superior bonding properties are noticable. :p
    I thought you knew that Ricardo :).
  • thejck
    thejck Posts: 849
    Thanks guys.. This can get confusing for a noob in SDA world.
    Mortite with the rings can't be beat IMO...
  • Conradicles
    Conradicles Posts: 6,373
    Ditto:cool:
  • helipilotdoug
    helipilotdoug Posts: 1,230
    Double Ditto :D
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • hearingimpared
    Ditto:cool:
    Double Ditto :D
    Question; wouldn't using Mortite with the rings make it damn near impossible to remove the driver's safely if need be?
    Hahaha, Larry when I run a spell check and it hits your screen name, it suggests DEVOLVING!!! LMAO!
    How? Please explain? Mortite/MD has no adhesive properties. The rings are pressed in from the rear and you're simply using the same type of screws to hold the driver in place. Instead of using the wood to secure the driver there's a durable metal ring to screw into.
  • hearingimpared
    heiney9 wrote: »
    Hahaha Brock you answered my question with two questions.
    I was just thing that since the ring is metal as is the stamped edge of the driver making contact that the Mortite would adhere to the point of causing a vacuum. Therefore more pressure would need to be applied to the side of the driver with a screwdriver or whatever to pop the seal.
    Okay, I've not installed my rings yet and haven't really read for comprehension and instructions all the methods put forth on installation. So in my mind the ring is on the side of the cutout that faces the driver, no?
    As Benny Hill said in his skit with him as the German pervert . . . "Learning all the time!"
