Center speaker with non-bridgeable amp
cnoat
Hello all,
Can anyone tell me how to use the single interconnect for the center channel off my pre to run a non-bridgeable amp.Y connector?Please anyone?
Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC
Sub SVS Ultra Tv 12
AQ T4 SC
Post edited by cnoat on
Don't really understand the question here, center channel is just one channel and you only need one of the two outputs on the amp, so you would only use one RCA. Splitting the RCA and feeding both lines to try and bridge it yourself is a bad idea, if that was the thought; just leave one of the amp inputs and outputs unused.Current System:
Paradigm Signature S2 v2
Conrad Johnson MF2500
Wyred4Sound DAC2
Audioquest Black Mamba II
For Sale:
3x Wilson Cub's
Conrad Johnson MF2500 -
I will try that right now.
Thanks sm88Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
It worked but the output is very low.I was gonna use the y adaptor not to bridge but to send a signal to both sides of the amp and then use the speaker outputs to bi-amp the speaker.Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
cnoat, it would be useful to know what amp you are using?
I know the Carver M-400 "mono" does actually use the 'Y" connection method, and then a specific hookup configuration, using both (+), but I would not try that on a different amp.
Have you read what your manual says? -
Its an old carver.A 1.5t I think.I just got everything set up and it worked very nice.I am just using it until I can get a three channel.Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
Good to hear you got it figured out.
