Center speaker with non-bridgeable amp
cnoat
cnoat Posts: 315
Hello all,
Can anyone tell me how to use the single interconnect for the center channel off my pre to run a non-bridgeable amp.Y connector?Please anyone?
Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC
  • sm88
    sm88 Posts: 353
    edited September 2010
    Don't really understand the question here, center channel is just one channel and you only need one of the two outputs on the amp, so you would only use one RCA. Splitting the RCA and feeding both lines to try and bridge it yourself is a bad idea, if that was the thought; just leave one of the amp inputs and outputs unused.
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
  • cnoat
    cnoat Posts: 315
    I will try that right now.
    Thanks sm88
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • cnoat
    cnoat Posts: 315
    It worked but the output is very low.I was gonna use the y adaptor not to bridge but to send a signal to both sides of the amp and then use the speaker outputs to bi-amp the speaker.
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • kcoc321
    kcoc321 Posts: 1,788
    cnoat, it would be useful to know what amp you are using?
    I know the Carver M-400 "mono" does actually use the 'Y" connection method, and then a specific hookup configuration, using both (+), but I would not try that on a different amp.
    Have you read what your manual says?
  • cnoat
    cnoat Posts: 315
    kcoc321 wrote: »
    Its an old carver.A 1.5t I think.I just got everything set up and it worked very nice.I am just using it until I can get a three channel.
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • kcoc321
    Good to hear you got it figured out. :D
