3.1TL's before and after
TrashyTrucker
Hey everyone,
Just wanted to show some proof (since I am the Newb here) that I am a fellow Polkie too. Here is my virgin speakers which still sound great BTW.
However I am starting this thread to show progress on upgrades on my 3.1's. Enclosed is some pics to show you nothing has been done so far.
Check the pic of my cd collection, Is that enough proof and do you think that entitles me to be somewhat of a true "audiophile" yet? Or do I keep the Newb sign for a while? :eek: LOL.
I will post more pics as I build...
Thanks,
Matt
Thanks,
Matt
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
Rotel RCD 1520 cdp
biamped to:
Post edited by TrashyTrucker on
Nice speakers for sure. You must be loving your music every time you play something.
But you have to fill that bottom row with CD's to advance past newbie..:D
JKMost people just listen to music and watch movies. I EXPERIENCE them.
tony millard wrote: »But you have to fill that CD cabinet with VINYL to advance past newbie..:D
JK
Fixed!:p
And I am not kidding.;)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Fixed!:p
So John, How is it you fixed TrashyTrucker's CD problem ??
TT: Nice Speakers, and Nice CD Collection!
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Ok all....
Just installed the RDO's and well:
Im not sure Im initally impressed to say the least, they compared to the SL3000 are not as "bright" they do seem "soft".
Is this due to some sort of break in period? I hope so.
I HAVE NOT done any other mods at this time. Perhaps the RDO's are NOT matched to my exsisting XO's? Perhaps I need to do the XO mod next to match the RDO's?
Thanks for help guys,
Matt
Rotel RCD 1520 cdp
biamped to:
...SDA's are just like candy for your ears... -
In audio everything needs to break in, why would tweeters be any different?
Give them 48 hours as they will sound kinda hollow at first.Political Correctness'.........defined
President of Club Polk -
I thought mine were subdued to at first but they did brighten up a little and then sounded great to me. About 40 hrs. is correct.;)
They will sound bright if you turn up the treble but I rarely do it.Most people just listen to music and watch movies. I EXPERIENCE them.
ABSOLUTELY it's because they need to break-in! You will be shocked when you let it run for 48 hours straight. To give an example, I replaced a tweeter in my left speaker, because of being pushed in by my son when he was younger. When I first fired it up, the whole left side of the soundstage sounded like it had collapsed - no space, no air, no life. It was boxy, and the sound stuck to the speaker cabinets. In the right channel, instruments floated freely from the cabinets, they had space and life to them.
I was expecting it to be different, but at first I thought....Did I hook it up backwards? Cause it sounds TERRIBLE! I thought...No, I double checked everything. It just needs to burn in Troy, It just needs to burn in. After 12 hours, I noticed good improvement. After 24, I noticed a major improvement. And after 48 hours, I noticed a huge improvement. By 2 weeks, it matched the other side perfectly and everything was beautiful again.
Give them 48 hours as they will sound kinda hollow at first.tony millard wrote: »I thought mine were subdued to at first but they did brighten up a little and then sounded great to me. About 40 hrs. is correct.;)
They will sound bright if you turn up the treble but I rarely do it.ABSOLUTELY it's because they need to break-in! You will be shocked when you let it run for 48 hours straight. To give an example, I replaced a tweeter in my left speaker, because of being pushed in by my son when he was younger. When I first fired it up, the whole left side of the soundstage sounded like it had collapsed - no space, no air, no life. It was boxy, and the sound stuck to the speaker cabinets. In the right channel, instruments floated freely from the cabinets, they had space and life to them.
Thanks guys,
Thats real good news! I thought maybe since I have been listening to the
SL3000's for almost twenty years that my ears have come accustomed to their sound. I also purchased some dynamat from my favorite retailer today as well... I believe I will affix that on the spokes of the cages that will be next on the aggenda.
But check this idea I have. I spent several hundred dollars back in the 90's (Its more like a grand today/google XLO trust me!)on speaker wire and came up with this idea what if I used 8gauge wire that is used for power applications? Ie... car amps etc. (nice and fat wire but real flexible) I found some reasonable priced stranded oxygen-free 8gauge from my retailer and here is a picture of it below.
It comes in both brown and red, I will let you know if this experiment works or not. Might be overkill but should allow less resistance between A to B. Since I biamp this should be a great match.
Thanks for reading,
Matt
MattIntegra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
If you mean as replacement chassis wire, some have tried that and reported no difference, but by all means, knock yourself out.
I see that you haven't upgraded your crossovers. Do that next and I believe you'll forget all about the chassis wire.Political Correctness'.........defined
I agree. If you're bored, worry about chassis wire, otherwise hit the more important...obvious stuff first.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I see that you haven't upgraded your crossovers. Do that next and I believe you'll forget all about the chassis wire.I agree. If you're bored, worry about chassis wire, otherwise hit the more important...obvious stuff first.
Ok guys,
I will get on the horn wed and call soniccraft. Ricardo left me with a very detailed version of his build, wish me luck.
Rotel RCD 1520 cdp
biamped to:
You will be happy when you are done and the capacitors are fully "burned-in". The 3.1's sound phenominal after the upgrade/replacement.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
The RD0's will be a bit softer, as you put it....I get that statement. Just give them some time but the overall timbre will be a bit different from the SL3000 that you're used to hearing.
Relax, as after you upgrade the xover assemblies, the whole picture will shift for the better, again. Even before, just realize that you're hearing something new and different...it's normal to critique obvious changes, just don't get wrapped up in it for now. Enjoy the music, evaluate much later.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
TrashyTrucker wrote: »Ok guys,
Matt
Man, does that sound hot.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Ok guys couple of questions,
First in Ricardo's post:
http://www.polkaudio.com/forums/showthread.php?t=47929&highlight=crossover
He used the Mills resistors 2.5 and 2.7 in parallel-(Mills MRA12)
1)Who or where do I get the resistors? (mills)
2)When I order caps (sonicap)I guess I should copy Ricardo's formula?
3)Are those foil caps? I noticed one of the previous 12uf caps says MYLAR... what is mylar? and I suspect that is a lower grade cap? than the new replacement?
4)Ricardo used a 0.1uF bypass capacitor (Sonicap Platinum) did he run that in paralell with the 12uf in the middle of the board? please use the link and photo's as reference. UPDATE: I read the post again and he stated he REMOVED the bypass cap...now I think Im confused
BTW also somewhere in one of Headrott's older post of his XO upgrade of the 3.1's he used, and I cant remember the value...
5) Headrott used a resistor in place of jumper(s) there is two on this board
a. why replace jumper wire...?
b. should I replace both...?
I appologize for sounding like the nerdy school boy...but remember I am the new resident NewB here!
Thanks for looking,
Rotel RCD 1520 cdp
biamped to:
Hi again Matt,
You can get the 12W mills resistors (2.5 ohm and 2.7 ohm) at Sonic Craft along with the Sonicraft capacitors. They are film capacitors but I am not sure anyone knows what type of film they are made from. Any fellow Polkie know? I found nothing about what they are manufactured from (other than a type of film). Mylar film capacitors are typically OK, but not outstanding (in most cases). Mylar is a type of film, made from polyethylene terephthalate (a plastic basically). I don't remember the values of capacitors that Ricardo used, but stick with the original values on the crossover and when you need to combine values (parallel capacitors) you should divide the total capacitance as evenly as possible between the two capacitors.
It has been decided that you should not use a bypass cap when high quality caps are used to replace the originals.
As far as me replacing the jumper in the s1 slot with a 0.5 ohm resistor it is a matter of taste and system set up, but I preferred it to only the jumper only. I recommend it, but it's up to your ears.
I think that covers everthing, but let me know if I missed anything or messed up on something.
Greg
Parts list, total.
Caps;
(4) 12uF
(2) 24uF
(2) 55uF
Resistors;
(2) 1.3 ohm, 12 watt
Remove and disgard the 750pF bypass cap. Do not replace with a jumper.
All parts are available from Sonic CraftPolitical Correctness'.........defined
Hi again Matt,
Greg
Thanks Greg for the help!
MattParts list, total.
Caps;
(4) 12uF
(2) 24uF
(2) 55uF
Resistors;
Thanks Jesse! I will order next week. They have been off the last couple of days due to the holiday and all.
Rotel RCD 1520 cdp
biamped to:
Matt,
Don't waste your time/money. Forget about the bypass. As you read, I removed mine a few days later._________________________________________________
Hey all,
Just sent payment to Sonicraft and sent payment to Larry last week! While I think I know what "spikes" do. But would someone educate me or point me in the right direction as to the following:
1)Why I need them?
2)I have threaded inserts and already have "feet" for lack of better term from a NewB!
3)What was the standard size threads in the SRS series? do Stubby or Headrott or Ricardo know? are they 1/4 inch?
4)What would be a good starter set for mine?
5)If you want me to research on my own thats ok and fine! ha ha LOL!
Thanks in advance,
Matt
total spent so far:
331.00 Sonicraft
110.00 Larry's rings - complete kit (mw+Pr + rdo)
96.00 RDO 198's
100.00 spkr wire 8 guage
Whew! are we there yet?
Rotel RCD 1520 cdp
biamped to:
TrashyTrucker wrote: »Hey all,
1)Why I need them?
Thanks in advance,
Matt
total spent so far:
331.00 Sonicraft
96.00 RDO 198's
26.00 Dynamat extreme
Alright guys! read some older post on what spikes do....! Done the research and searched for spikes but I have yet another question?
1)If I use spikes on carpet, would someone suggest shouldnt I use pads?
Mye sound says No! in this. Thanks hearingimpaired!
http://www.myesound.com/Points_n_pads.html
These wont hurt the carpet?
Can I get buy the ones for 10.00? or spurlge on the heavy ones?
If so I guess I need to ask them if I can get the big ones at 1/4-20 :rolleyes:
My SRS little brother 3.1's - weigh in at 101lbs a piece.
Thanks for looking,
The New generation of NewB(s)
Rotel RCD 1520 cdp
biamped to:
Get the big ones and yes, you can get them with 1/4-20 thread. Do not use the pads on carpet.
Who cares if they "hurt" the carpet!?!Political Correctness'.........defined
Spikes will do no more harm to your carpet than a couch sitting in the same spot for several years. Probably less.
Don't use a pad on carpet. It negates the effect the spikes would have in the first place. -
Hey all,
They dont make the larger ones (1/2UNC) in 1/4-20. :mad:
1) what now? redrill to accept the larger ones? Put new inserts in?
If I do that, the spike will have to stay on there always. I could appreciate the flexability to switch back to what is on there now if I wanted to! Whats wrong with the smaller one (spike) of the two? See pic in link, 1st from the left! will that small one work too?
I am also waiting to hear from Mye sound as well as to his suggestions.
Thanks for looking guys,
Rotel RCD 1520 cdp
biamped to:
I believe what F1Nut meant is simply get the biggest spike you are able from MyeSound. If I'm mistaken, he'll snap my neck. Stick w/ 1/4 20" thread as its the Polk standard.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Ok! thanks dorokusai. I thought he too (Jesse) was talking about that same way but wasnt quite sure.
I did NOT want to change the thread size if I could help it.
Rotel RCD 1520 cdp
biamped to:
Sorry for the confusion, Matt. Grant use to sell two sizes in 1/4-20. It appears that he is only selling one size now.Political Correctness'.........defined
Jesse - I believe he will do other sizes but you have to ask and it depends on if he has other orders to justify the cost. It's not cheap for him to make them and the back end isn't all that much.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Hey all,
Finshed the mods... I did dynamat, rings, and XO's all at the same time.
I would like to take this time and my thanks goes out to EVERYONE who was involved. Thanks again for your pics and tips and most of all your support.
It was a little tricky as Greg (headrott) explained in his post. You almost
have to "carve" the braces to install the rings. I found it easier to use a dremel
and to carve away at the braces a little at a time untill the rings fit. The rings
fit like a glove, I am very impressed with Larry's work on them. I am very pleased with the overall and integrity of this build, the rings allowed me to snug the bolts up real tight. Something that was not possible with the original standard screws that were factory.
The dynamat was a snap, however it was messy... LOL
The XO's were not that bad either. Like I stated earlier, I had much help with the other members supplying pics of their builds (Ricardo)
I had one problem with my cross over which I will post next.
Thanks for supporting me (Stubby) and especially (F1nut) who gave me the idea of and the confidence to tackle on these upgrades. Much appreciated
Here is some pics of the build(s),
Matt
Rotel RCD 1520 cdp
biamped to:
Here are some more pics
Rotel RCD 1520 cdp
biamped to:
