MM6501 in SEALED pods? 2 mids per pod *With Pic
monkeyleg
Anybody know how these will sound in a sealed enclosure? I havn't found any T/S parameters. I don't need to play below 90HZ. There will be 6 sets in the car so I'm not worried about max output/efficiency. Maybe fill with polyfill or cut out the back holes in the back of the pods?
Pics of pods =
http://s916.photobucket.com/albums/ad5/cz3chmonkey/?action=view¤t=august104.jpg&newest=1
Pics of pods =
Post edited by monkeyleg on
Yea for each of the 4 doors. They fit two 6.5", two 1" tweeters, and two 3" T.Vs
Posted it for you.
Nice looking panel. Adding polyfill will make the speakers sound as if they're in a bigger enclosure btw, and if you don't need them playing anything lower than a specific freq I'd say just use your HU or amp's built-in XO
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Pics of pods =
Good luck with phase and cancellation issues. Do you really need 12 mids plus tweets in a car? -
Thanks for posting the pic! I need to know what the mids will sound like in a sealed enclosure. I have used them in a free air application, just like everyone else with a speaker in a car door but I would like know what the difference in sound will be. Anybody know from first hand experience? All the speakers will be amped over 100rms, and yes, I do need all 12 mids, 12 tweeters, 2 sealed 10" in the seats, a ported 15", and over 17 T.V.s. That's what I find fun to build and see in action
I'm picturing a disco inferno school bus with a psychedelic paint job. Pass it around dude.
Might get better results at the smd forums. You'd fit right in.Dodge Ram 1500 SLT Quad Cab 2007
Pioneer DEX-P99RS, IPOD Touch 64gb, Rockford Fosgate T1000-4, T600-2 & T1500-1bd CP
Polk Audio SR speakers, 6.5's, 5.25's, SR tweets and 2 SR124-DVC subs in 1.57cu ft sealed enclosures -
I'm a member of SMD, have been for a long while. Only problem there is, nobody uses Polk. Seeing as I am using Polk products and there are people here that also use/like Polk products I figured it wouldn't hurt to ask my question.
vas close to 0.5cu ft would be my guess just by comparing other 6 1/2" drivers. Best i can do dude.
I'm a member of smd as well Monkey. Wasn't meant as a bashing. Some of those guys are really knowledgeable. You're right in that they aren't into Polk now. But a lot of them have used Polks.Dodge Ram 1500 SLT Quad Cab 2007
my sr mid bass became more punchy in a sealed enclosure.
Do you know the rough volume of the sealed enclosure? Did you notice any difference in how loud they are after?
I forgot the exact size, but it was around .3. Tbh, I didn't see any perceivable difference in volume. -
Have you called polk? I'm sure they can direct you in the right direction.
Yea I shot them an e-mail months ago and no reply -
Ok, awesome, thanks. -
Look at people's builds. I have never done it before but I've been an SMD member for years so I've seen some very talented people fabricate amazing things. I just planned and executed. Step by step. Take it slow and TEST FIT. For the love of god Test Fit.
evr find out sealed parameters?Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
not true ones, but I've talked to lots of people that tried sealed pods and they couldn't be happpier
