Low Volume on Atrium 45 Outdoor Speakers
Robbbyva
Robbbyva Posts: 1
I have the Polk Atrium 45 Outdoor speakers. I have the speakers hooked up to a Harmon Kadron receiver. When i adjust the volume for the outdoor speakers, the inside speakers are quite loud. Conversely, if I lower the volume so the inside speakers are fine, the outdoor speakers are barely audible. Any advice?
Thanks - Rob
  • cseils
    cseils Posts: 10
    edited September 2010
    How are they connected? Multiple zones on the receiver?
  • thsmith
    thsmith Posts: 6,082
    It could be the difference of load and efficiency in your outdoor vs indoor speakers, could a long run of wire with to low gauge of wire.
    Have they both worked well before or is this your first hook up ?
