Low Volume on Atrium 45 Outdoor Speakers
Robbbyva
I have the Polk Atrium 45 Outdoor speakers. I have the speakers hooked up to a Harmon Kadron receiver. When i adjust the volume for the outdoor speakers, the inside speakers are quite loud. Conversely, if I lower the volume so the inside speakers are fine, the outdoor speakers are barely audible. Any advice?
Thanks - Rob
Thanks - Rob
How are they connected? Multiple zones on the receiver?
It could be the difference of load and efficiency in your outdoor vs indoor speakers, could a long run of wire with to low gauge of wire.
Have they both worked well before or is this your first hook up ?Speakers: SDA-1C (most all the goodies)
