Lsi9 power requirements
While a Denon 3311CI properly drive Lsi9 and a LsiC?
Post edited by Hungaro on
I don't see anything about it being rated for 4ohm operation, so I would say no."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The specs say that it has "low impedance drice capability", but it doesn't say that it's stable at 4 ohms. You'll need a separate amplifier that is 4 ohm stable to get the most out of the LSi's, and to protect your speakers and AVR. That Denon has 7.2 channels of preouts, so it would make a fine pre amp.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
I've got the 3311ci powering the mids/highs of my Rti A7s. I'm going with a parasound amp in a few days and plan to use the preouts as well. Even bi-amped with an Onkyo amp, I think a dedicated amp will do more.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Thank you for your replies
Welcome to Club Polk Hungaro.
Start looking at new or used amps. Your Polks will not operate to their full potential with just a receiver.
I always recommend getting at least a 200wpc @ 8ohms, this way you will have enough power to drive almost any speakers now & in the future.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
