speaker setting small or large.
conqur
conqur Posts: 80
edited September 2010 in Speakers
i've been tweaking my system yet again. my front stage is nothing to brag about so i'll leave the name of the speakers in question out. anyhow. i'm trying to figure out if setting my speakers to small is giving me the best from my center and l and r speakers. i have subs and i know that the subs should handle the bass and the lfe. so who sets their speakers to small/large and why?
Post edited by conqur on
  • Bobsama
    Bobsama Posts: 526
    It depends on the design of the speakers as well as how they're setup. If you route power from the receiver to the subwoofer to the speakers, then you should set the system to Large. If you are running from the receiver to the speakers and route signal from the receiver to the subwoofer, you'll typically use the Small setting. The real issue, to me, is that setting the receiver to Small means you have an additional crossover in the mix--which may degrade audio quality with some loudspeakers.
    If/when connected to a receiver, I run my SDA-1's and Monitor 5's on "Large" mode, since both are full-range speakers and the fact that I don't own a subwoofer. :p
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • Ricardo
    Ricardo Posts: 10,634
    I set my fronts as small, and let the sub handle all that power-hungry lows. If I had a separate amp I would probably leave them as large.
    SOPA
  • Vdr1973
    Vdr1973 Posts: 72
    Im running my fronts small as well due to the fact the my AVR is my weak. And the sound is flat with weak bass in Large.
  • dekuda
    dekuda Posts: 756
    I am running my RTi12's at small eventhough it was against my way of thinking. Even with my Parasound amp at 205/w I still did it. In my opinion a good sub or two will produce better bass than any towers can. I switch back and forth between small and large and it convinced me.:D
    Here is a interesting article that made me even think about it.Try it and see !
    http://www.audioholics.com/tweaks/get-good-bass/bass-management-basics-2013-settings-made-simple
    Setup:
    MARANTZ SR7002 AVR
    Parasound HCA1500A Amp
    Rotel RCC-1055 Cd Player
    Pioneer BD320 Blue Ray
    AQ4's speaker Cables
    PNF Icon IC
    D H Labs IC
    PS Audio xStream Power Cables
    Samsung 52” LCD
    Mains Polk RTi12’s
    Center Polk CSi5
    Surrounds Definitive Technology BP2X
    Subs Mirage Omni S 10’s (2)
    Don’t sweat the petty things!
    Don’t pet the sweaty things
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • pearsall001
    pearsall001 Posts: 5,373
    Set them both ways & give a listen. Go with whatever sounds best to you. Bear in mind though that very few speakers are truly "full range" & will benefit with a sub (or better yet...two). Here's a nice article to read & do a search on the topic for more info. http://forum.ecoustics.com/bbs/messages/34579/128214.html I have my mains set at 50Hz & the center & surrounds at 70Hz. Sounds incredible for both two channel & HT.
