help help plz
warviper
warviper Posts: 585
wow i have always stuck to the never turn it past half way mark on my avr and i just realized that my avrs max is 0 db does that mean that -50db is half i have been listining at -25 dbs with no distortion sounds alll clean no clip im so confused. the only reason i found out was i went out and bought a spl meter and am going to start to calibrate please respond.
hanging on every word
war
p.s my avr is the yamy rx-2300
Wish I was a polkologist then I could call my self Dr.warviper.
Post edited by warviper on
  • gatemplin
    gatemplin Posts: 1,595
    edited December 2003
    The numbers dont mean anything other than as a reference. From what I understand though, -22dB ( or every three dBs) will be twice as much power as your usual listening level of -25dB if that helps. I could be wrong though.
    Graham
  • warviper
    warviper Posts: 585
    uhhh how can the numbers not mean anything? :confused:
    F1nut Posts: 52,175
    The numbers are a REFERENCE POINT, same as 1-10 on some volume controls. You've been doing the right thing, don't go past halfway and everything will be fine.
  • pjdami
    pjdami Posts: 1,894
    Different manufacturers use different volume settings on their receivers. This can be kind of confusing to the user really. Like F1 said though it is all a reference point. Some manufacturers like Rotel and Onkyo use the increasing volume numbers. B&K and I believe Denon use the decreasing volume with negative and positives.
    I had a Yamaha RX-V1300 earlier this year and yes depending on the recording -30 db was still clean but past -25 db I would start hearing some compression of the music. Your 2300 may sport some better amps but no way that you can go all the way to 0 on your receiver. For your receiver you are going to have to pick a volume close to 85 db when you calibrate using one of the calibration DVDs and adjust your other speakers accordingly to this "reference" volume setting. It may well be around -35 db or something like that.
    Paul
  • warviper
    warviper Posts: 585
    glad to here you have own a yamaha my main question is that there is a bar graph under the volume and then there are the -db thing to my best judgement half way on the graph is -14db so is that to high thats way too loud for me i just want some peace of mind. thank you paul, f1, gate please repost if i have clarified my amp.
  • steveinaz
    steveinaz Posts: 19,546
    As mentioned above, the dB labeling is pretty meaningless. The reason being different sources, ie. CD Player, DVD, etc, will all have different input levels. The only way to avoid clipping (without having true clipping indicators) is by listening. When the material begins to sound "stressed" "disorganized" or you hear even a hint of cone break-up..the amp is clipping.
  • warviper
    warviper Posts: 585
    ohh ok what about the graph then?
    F1nut Posts: 52,175
    Eff the graph! Just relax and listen to the music.
  • steveinaz
    The "graph" is "eye-candy" for the general population. Kinda like the spectrum analyzers Kenwood sold in the early 80's that had no pink-noise generator built-in, they looked really cool, but they were useless.
  • warviper
    warviper Posts: 585
    Im gonna do more research. Thanx for the input but efing the graph doesnt make sense. Sounds funny but doesnt make any sense. I think it has to do with the fact that for every 3 db boost in sound you need to like double the watts. Thats why at -50 db its only at a quarter on the graph and at -25 dbs it at half on the graph and it takes half the graph to go the last 14 dbs cause double 20 wats is way less than double 50 watts. lol I hope this is making some sense. :D
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Do a search for calibration and there are some very complete threads in that regard. Channel balance and calibrate your system to Reference Level with a test disc and a SPL meter and get back to us if you have any questions.
    SVS
  • warviper
    warviper Posts: 585
    hey doc i got a spl meter and a the video esentials discs do you have any experience with it.
  • ken brydson
    ken brydson Posts: 9,063
    He wrote the book. Do a search, you'll probably find 1000 threads
