Enough power? Monitor 70's/CS2 & Pioneer 1120
I ordered a Pioneer 1120 and have Monitor 70's/CS2 center with a HK sub and rears. I was wondering if anyone else has this combo and if the Pioneer would give the L/C/R speakers enough power? I understand that these Polks really open up when powered properly.
I was thinking about getting a Emotiva 3 or 5 channel amp to boost it up a bit.
Necessary?
I know I will have a better idea when I finally get the 1120 hooked up, but was curious.
Necessary?
Post edited by drewh01 on
Just my opinion, You could spend your money a little wiser on something other than an EMO....other than that looks like your on the right path.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Knucklehead wrote: »Just my opinion, You could spend your money a little wiser on something other than an EMO....other than that looks like your on the right path.
ok, i'm open. What would you recommend? -
Look at Adcom, Rotel, my Rotel sounds really nice with my Polk's.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Thanks for the info - I will start my search on a model that will fit my needs and price range (under $500)
I don't believe you have any problem in regards to power but once you folks get your mind set, there's usually no turning back. It's a 90+db efficient speaker. Don't confuse more power with dedicated power.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
yes, that is true. I may find that it is plenty of power but it is fun to shop! -
You'll be fine on what you have. If you have the urge,spend a couple hundies on a used amp if you want. Sure won't hurt anything. As you sit though,your good.HT SYSTEM-
lsi 9's -
Just got my 1120 - it is quite an improvement over my HK 135. Really great sound and the Monitor 70's sound great! If I can find a $200 amp i'll give that a try too.... -
One other thing is that now I am needing to replace my crappy 2 rears and side surrounds. I need something that I can mount in the back corner & along the ceiling edge of the room as our sectional is up against the back wall. Optimally I need to be able to point the speakers in a downward angle.
What would match my current setup and still give me great results? -
I've got a 1120 that powers Monitor 70's, 60's and a CS2. Works just fine.
Polk's OWM3s would fit that bill nicely if you have space constraints up there....also look at the OWM5s if you can fit a slightly larger speaker up high?
and WELCOME TO CLUB POLK!
Polk's new Blackstone TL series would make a nice match for surround speakers, when they become available, which they may be? If you want something a little bigger, the Monitor 30's are easily wall mountable and would match your other speakers perfectly.
As far as the amp goes, look into the used market, try a few out and let your own ears decide. The nice thing about used amps is you can usually get your money back if you're not satisfied. And if you end up liking the Emo, then you came to that decision on your own. I would definately play the field for a while first though . .Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables -
Welcome to Club Polk. I completely disagree with what Knucklehead says. I feel that he is just voicing some unfounded anti-Emotiva sentiiment that happens here from time to time.
Reported....trolling.:rolleyes:Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I'm running the same front stage and receiver, with Emotiva ERD-1's for 5.1 surround... And loving it!
However, like you, I'm also looking at amps to really push these speakers to their full potential. If I can find a used Emotiva XPA-5 for under $550, I'll be all over it.
I already love the Polks without an amp, so I know I'll be in HT heaven once I grab an amp.
Welcome Drew.
The XPA 3 or 5 will definitely power all of your speakers to thier full potential just fine if that is the direction you want to go.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
