Updating my 7B crossovers
misterwhisker
Looking at the sticky thread and the schematics this is the parts list x2.
12uF capacitor
27uF capacitor
2.7 ohm resistor
.22mH inductor
1.75mH inductor
Can someone confirm and also let me know if there is a single vendor that has all the parts.
Also the part numbers if someone has them handy.
Thanks much!
Brian
12uF capacitor
27uF capacitor
2.7 ohm resistor
.22mH inductor
1.75mH inductor
Thanks much!
Brian
Pull your x-overs to confirm the cap and resistor values. Leave the inductors alone, replacing them is moot point. Sonic Craft will have the caps and resistor(s) you need, give them a call next week. http://soniccraft.com/"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
So I want to duplicate the resistor and cap values that are currently on the crossover?
No value deviations, correct? -
Yes, but it's ok to use higher voltage caps and higher wattage resistors."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Is the 1.75mh a steel laminate or ferrite core?ave the inductors alone, replacing them is moot point. -
Air core."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Then yes save your coin.
