Updating my 7B crossovers
misterwhisker
misterwhisker Posts: 49
edited August 2010 in DIY, Mods & Tweaks
Looking at the sticky thread and the schematics this is the parts list x2.
12uF capacitor
27uF capacitor
2.7 ohm resistor
.22mH inductor
1.75mH inductor
Can someone confirm and also let me know if there is a single vendor that has all the parts.
Also the part numbers if someone has them handy.
Thanks much!
Brian
  • Face
    Face Posts: 14,340
    edited August 2010
    Pull your x-overs to confirm the cap and resistor values. Leave the inductors alone, replacing them is moot point. Sonic Craft will have the caps and resistor(s) you need, give them a call next week. http://soniccraft.com/
  • misterwhisker
    edited August 2010
    So I want to duplicate the resistor and cap values that are currently on the crossover?
    No value deviations, correct?
  • Face
    Face Posts: 14,340
    edited August 2010
    Yes, but it's ok to use higher voltage caps and higher wattage resistors.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    Face wrote: »
    Is the 1.75mh a steel laminate or ferrite core?
  • Face
    Face Posts: 14,340
    edited August 2010
    Air core.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    Then yes save your coin.
