spikes from parts express
sda2mike
sda2mike Posts: 3,131
edited August 2010 in DIY, Mods & Tweaks
Post edited by sda2mike on
  • Face
    Face Posts: 14,340
    edited August 2010
    They're ok as long as your speakers aren't over 50-75lbs. I've broken a few with my 100lbs Tannoys.
  • sda2mike
    edited August 2010
    Face wrote: »
    hmmm...2b's are abt 80lbs...feel like more, tho
  • Face
    Face Posts: 14,340
    edited August 2010
    I can't get the site to work right now, but check out: https://myesound.com/
    pitdogg2 Posts: 27,245
    edited August 2010
    try these in the 1/4 X 20 threads they are a bit better than the set at parts express. I've used both and my experience the madisound are better and my speakers are 150 lbs. that i used them on.
    https://www.madisound.com/store/index.php?cPath=404_121
    if link don't work search tiptoes/feet
    mhardy6647 Posts: 35,203
    edited August 2010
    Face wrote: »
    What actually broke? Not being snide, just curious about the failure mode.
    I'll be getting my "Bill Fortier" corner cabinets for a pair of Altec 604Es soon (they're all built and paid for now) and they are supposed to be spiked... but at 9 ft^3 inside and Baltic Birch plywood outside... I think they're pretty beefy.
  • Face
    Face Posts: 14,340
    edited August 2010
    The threaded portion of the tip is the weak point. If the spike was backed out at all(to level the speaker), tilting the speaker onto that point shifted the tip inside the base, making it cockeyed and locking it in place. Or they've sheared off completely at that point.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2010
    You cannot miss with these;
    http://www.myesound.com/Points_n_pads.html
    I would get the heavier one, second from the right. Best of the best out there IMHO!
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited August 2010
    I use them on my 2B's and my maple speaker stands. I have not had any issues but I am sure the Mye Spikes are better and the cost reflects that.
    The Parts express spike use a 6mm fine thread. Not the 1/4 20 thread.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
