Help me pick a sub...
Okay, so I have been slowing putting my system together and it is almost complete, with one key component missing... The boom. Here is what I have so far...
Pioneer Elite Vsx-23 AVR
Emotiva XPA-5 amp
Polk LSi25's
Polk LSI-c
Polk LSi-Fx's for the surrounds.
AudioQuest cables
This system will be specifically for Home Theater use.
What would you recommend for a sub? I can get dealer pricing on Polk, and Velodyne subs, so if I can choose one of those that would be ideal.
Thanks everyone.
Emotiva XPA-5 amp
Polk LSi25's
Polk LSI-c
AudioQuest cables
Thanks everyone.
Post edited by E-ride on
DD Velo....15 incher....got coinage ?HT SYSTEM-
lsi 9's -
Polk Micropro 4000
Velo SPL series & don't look back!! Twins if you can swing it.
You did not say how much you want to spend but the Velodyne would be my choice as well. Eddie
Sunfire True Sub!Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
I have Epik Sentinel for sale if you are interested. It is like new condition. Email me if you are interested. I bought it new in Dec'09 but decided with something smaller. So this has been put back in the box for a while.
Thanks guys, I was hoping for around $1000 if possible. The problem with used is that I live in Canada and the shipping rate would be killer. A DD12 from my supplier is $1500 brand new. What do you guys think of the Optimum 12?
Anywhere to go hear/feel one? If so,do both music and ht if possible.Good Luck with your search.What about Paradigm sinnce you are in Canada???
Velodyne makes a stellar product! My HGS-10 has enough slam to fill an airplane hanger. Well, I might be over-stating...a little. But, I truly can't believe how much bass comes out of this thing. Too bad I barely listen to it anymore (it's too much for most of my low level 2 channel)..... ><////(*>
How is the micropro 4000 for strictly HT use?
(Tweak City Audio) TCA CS10.2 or CS18.1 or CS18.2.
Not Aff.engtaz
You can't go wrong with an SVS.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
After auditioning a few subs yesterday and talking with some experts in regards to the layout of my room and best bang for my buck at this point. I am going to go with 2 Velo MiniV-10's placed in opposing corners of the room. I can always sell and upgrade to the big dogs later if I want. Thanks for all of your help!
How is your setup now?. I have exactly same speakers and Amplifier. but went with Micropro 4000 and i am happy with it. Wondering how 2 subs would sound instead of one. -
The MiniVee 10's should sound incredible, esp if you can swing 2 of them. I picked up my Velo DPS-12 during the final days of Circuit City for $230 on clearance. (used to sell them for $699.99) If I had the extra cash back then I would have bought two. Running the DPS-12 in tandem with an Infinity PS210. Still checking flea bay for a good used DPS-12....polk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
Polk Micropro 4000
+1 or get two of them if you can get the great pricing on them.
otherwise if not Polk I would go SVS, epik, or DIY. -
veerapaneni wrote: »How is your setup now?. I have exactly same speakers and Amplifier. but went with Micropro 4000 and i am happy with it. Wondering how 2 subs would sound instead of one.
Been piecing this system together for the past couple months, now have all of my speakers, AVR, and amp running with a cheap 12inch sub right now. Will be picking up my subs here in the next month or so. Right now it sounds incredible, can't even imagine it with quality low's. Can't wait! Will post an update, can grab a MiniV10 for like $400 I think. -
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I love my Velodyne!
There's a B stock PB13 Ultra in rosenut available now for $1499
https://svsound.com/store/index.cfm?fuseaction=product.display&Product_ID=150&CFID=271180&CFTOKEN=91943715 -
How about Rythmik. I love mineSDA SRS 2.3tls; RDO 198's, Dynamatted, Armaflexed, Gimpod Boards, Crossovers by quadzilla: Clarity ESA 630V, Mills Resistors, Track Audio Spikes, Musky's Curly Maple Caps
CSi5, FXi5, Rythmik D15SE sub, Pro-Ject Xpression III/Ortofon MC-3 Turbo. Pro-Ject Speed Box. Pro-Ject Tube Box II -
There's an SVS PC13 Ultra for sale for $950. I placed the link in the Deal of the Day section. Good luck.7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi -
