Carver TFM-42 noise
Osarion
Hey guys, when I turn on my amp I get a loud humming noise. The volume of the noise goes up and down, but it's pretty loud overall. I switched it out with a tfm-25 I have and the problem is gone so I know it's the amp.
So the question is, is there anything I can check? If not I'll have to put it away for a while as I can't afford to have it serviced anytime soon. Thanks in advance for any help/advice. Chris
Post edited by Osarion on
Probably a power supply related issue. Unless you know what you are doing, have the schematics and various test equipment, there's nothing you can service yourself.Political Correctness'.........defined
President of Club Polk -
Jesse is almost certainly right on the money, but just in the off chance it could be a ground hum issue if the power cord has a 3 prong male end try a cheater plug just to see if that could be the issue.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
no need for the cheater adapter the TFM42/45 only have a 2 prong plug. Could also be one of the cap's is bad my TFM45 had a buzz that when sent to service was a bad cap I had them replace all that shared the same circuit as the bad one
my .02 -
I guess it's off to the closet for a while. Thanks for the replies everyone.
my tfm42 buzzes on turn on but only on turn on, it's gotta be a cap or something....it will be going to get service when it finally goes. it sounds like it is time for yours. search on here, I know someone here knows where to send it......boys?
definitly worth it to get serviced!!!!!Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
This amp was serviced at Rita's by the previous owner last June and had some caps and resistors replaced and a few other internal touch ups. Just missed the one year warranty haha. It's worse than a hum, It's like a loud feedback sound. Not the high pitched screeching feedback but still feedback sounding. This is with or without the preamp on and with or without music playing. Of course I didn't screw with it too long out of fear of damaging my speakers.
Either way Ohskigod, I always see people being referred to Rita's for Carver service. http://http://www.ritasvintageaudio.net/ -
yep, sounds familiar.. havent heard n instance where one ws sen then went south......wierd. even so, still gotta get it fixed....where else you gonna get an amp like that for the price of the repair?
keep us posted bud.Living Room 2 Channel -
Try Rolland at Hi-Tech Audio Ltd.
2125 SW 19th St.
Gresham Oregon 97080
503-618-7605 Fax 503-674-8593
http://www.carveraudiorepair.com
I believe he charges a little more, but he's got orginal parts that no one else has and from what I hear, he does a better repair job.Political Correctness'.........defined
Jesse is correct Rita is good but she just does not get as deep into it as Roland will. I have had some to Rita more than once for the same problem shipping is not cheap and my time without my gear is BS. Roland will do it right the first time with the finest parts which just might be way better that OEM. You hear it on here all the time a lot has changed in the Cap making for the better in the last 25-30 yrs.
2125 SW 19th St.
+1
I have used Rolland twice and in both cases very happy with the work.
I am not so sure that Rita's prices are any cheaper now but I always felt better sending my stuff to Rolland.Speakers: SDA-1C (most all the goodies)
Try switching the polarity of the plug.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
