Mercury Capri Project Car
24
  • indyhawg
    indyhawg Posts: 1,671
    edited August 2010
    Looks like a fun project. I had an 82 Capri back in the day. It was a fun little car.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2010
    Well I got it!
    The big thing was a big split in the intake hose after patching that and holding my foot down for it to warm up it found its idel speed and was fine!
    Now correct me if I am wrong but rough cold warm ups and than running smooth after warm up means the pvc valve?
    After wash
    Scrubbed the top down before and after
    Clayed and waxed
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
    billbillw Posts: 7,504
    edited August 2010
    Nice ride for $500. I'd get it road worthy, then sell it to some high school chick for $3000 or so.
    I can hear it now...
    "Oh Daddy, I just think its soooo CUTE! Please!"
  • kuntasensei
    kuntasensei Posts: 3,263
    edited August 2010
    Well I got it!
    I was thinking EGR valve, but... you may be right. It has been a while since I've done any monkeyin' around on cars. :D
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • jflail2
    jflail2 Posts: 2,868
    edited August 2010
    Billbill hit the nail on the head. That looks to be an easy flip after seeing it cleaned up!
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2010
    jflail2 wrote: »
    +1
    Not bad, for a chick car ;):p
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • pmlewis
    pmlewis Posts: 100
    edited August 2010
    Your car did clean up nicely. I have a 92 N/A automatic. It has been fairly reliable, but these cars do have there fair share of quirks. The 94's seem to be the nicest. You will definitely want to get a Merc shop manual. I have found it to be extremely helpful. Also checkout Mid County Classic Mustang for NOS, used and repro parts. http://www.midcomustang.com/.
  • bigaudiofanatic
    edited August 2010
    Thanks and I doubt I will be selling it.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • pmlewis
    pmlewis Posts: 100
    edited August 2010
    If you are going to use it as a daily driver you may want to look into picking up a hard top for the winter. It keeps the car much warmer and quieter. You also get dome lights and a rear defroster! Rear visibly is also improved.
  • bigaudiofanatic
    edited August 2010
    Na, this will be for nice weather I have my civic for going back and forth to school. If I find a hard top at a good price I might take it. I will use a car cover in the winter and wipe the snow off so it does not stress the top. That being said this car sat threw our big bad snow storms last winter.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited August 2010
    More pictures
    The dash just needs to be scrubbed a bit more and the spots will come out.
    Not much space for speakers
    Rear seats not bad for leg room
    Hide away top
    Rear speakers
    The trunk
    Rear shot
    Also a side note, the rear view mirror was just laying in the floor when I started. Used a repair kit and is now back on.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • gelinas
    gelinas Posts: 226
    edited August 2010
    looks like a fun project.
    Were you able to drive it home from your friennd's house?
  • bigaudiofanatic
    edited August 2010
    Not yet need to register it and insure it. All will happen by the end of next week.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2010
    Hard start smooth idle is usually EGR. If it is the PCV that is cheap. EGR a bit more expensive. It could also be the gas. How old is the fuel in it? If it is older than a year get a stabilizer or empty it out and get new.
    Run it a couple of times and get new gas. It may clear out on its own.
    Looks good, cleaned up well.
  • bigaudiofanatic
    edited August 2010
    I did put 5 gallons of new premium gas in. I went and started it this morning and it started right up sputtered a big and smoothed out. I think it is the ecu relearning its positions but I will see. If it does not change I will replace both the pvc and the egr.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • concealer404
    concealer404 Posts: 7,440
    edited August 2010
    Don't bother replacing the EGR. Just remove it and cap the lines going to and from it.
  • ESavinon
    ESavinon Posts: 3,067
    edited August 2010
    Why Premium gas? Premium gasoline should only be used on high compression engines.
    You should give that engine a complete tune up. Clean the intake, and the injectors. Check the battery see if it holds a charge. Replace if necessary.
    Replace all the filters and all the fluids (Engine, Tranny, Radiator, Power Steering, and Brake).
    Inspect your brakes. Make sure your Brake cylinders are not frozen or rusted.
    You will need to sand down the rotors and drums before you take the vehicle for a spin otherwise you're going to have to replace the brake pads.
    Check your fuel pump. Put a container of gas antifreeze and do not put anymore fuel or additives until you burn off almost all the fuel left in your tank. Replace the fuel filter and the fuel pump filter (it's a small sock filter that's located inside the fuel tank).
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • ESavinon
    edited August 2010
    It's there for a reason. Don't mess with the Emission system unless you know exactly what you're doing. Doing so will not allow you to pass NJ's strict Emission /Inspection.
  • bigaudiofanatic
    edited August 2010
    ESavinon wrote: »
    I guess you did not see the pictures. I installed a bran new battery the old one was sitting for 5 years i was dead as a door nail. Drained as much old fuel out as I could put new high tes fuel in to help clean out everything, also the bottle of injection cleaner was added which was also in the pictures. A I said later I did test and the fuel flow was fine and clear. Brakes are fine but will flush the fluid out and put new in. Fluids are being replaced. Not trying to be rude just there is a lot of info I already put in the description of things and the pictures.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • ESavinon
    edited August 2010
    The only difference between regular gas and premium is the octane rating. All fuels have the same amount of detergents. The fuel system should be cleaned professionally.
    Inspect the brake cylinders carefully. You don't want brake failure at highway speeds.
    My previous post was meant as a general guide for a vehicle that has been unused for a while.
  • bigaudiofanatic
    edited August 2010
    The higher octane burns cleaner and plus it was to help whatever stale gas that was left in the tank. Brakes will be upgraded later but I see nothing wrong with them now, I will clean them up and install new fluid and bleed the lines next week. I have only been working on the car for 2 days I know I still have a lot to do but I am going to drive it and work on things as well. Thanks for the info though.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • ESavinon
    edited August 2010
    Higher octane burns cooler not cleaner.
    Octane rating
    For more details on this topic, see octane rating.
    Internal combustion engines are designed to burn gasoline in a controlled process called deflagration. But in some cases, gasoline can also combust abnormally by detonation, which wastes energy and can damage the engine. One way to reduce detonation is to increase the octane content of the gasoline, which is expressed by its octane rating.
    Octane rating is measured relative to a mixture of 2,2,4-trimethylpentane (an isomer of octane) and n-heptane. There are different conventions for expressing octane ratings so a fuel may have several different octane ratings based on the measure used.
    The octane rating became important as the military sought higher output for aircraft engines in the late 1930s and the 1940s, with higher rating indicating higher compression ratio.
  • concealer404
    edited August 2010
    Ehhh... you could look at is as a "safeguard" against detonation if the car has some major carbon build up. But i agree otherwise, not worth running premium in there.
    That said, get a timing light on the thing, too. I always run premium on my cars when i buy them until i've had a chance to do a complete tune up, just to have a little more "wiggle room." I don't know if it's really doing anything, but it makes me feel better.
    As for EGR, forgot you were in NJ, my bad.
  • bigaudiofanatic
    edited August 2010
    I run it in my bike in my car and we ran it in our 96 honda that lated for 298k miles. I do not run it all the time like he might be thinking but it was just something that made me feel better to run right now.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2010
    Wow, 298k miles of premium gas. I hate to think of how much wasted money that represents!
    What're your next plans for the Capri? This is really making me want some kind of a project!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • John in MA
    John in MA Posts: 1,010
    edited August 2010
    Oh man. My family's neighbor had one of these for years. My father and I both thought it was about the most unpleasant little car either of us had been in. It's like they took a Miata and removed the power, handling, quality, and comfort.
    You can probably get a manual Miata for about what this would cost after all the drivetrain swaps.
  • kawizx9r
    edited August 2010
    ^+1
    Had a Miata MX-5 myself, and if John is right about the power/handling/comfort/quality then IDK what to say about the Capri.
    However, there's nothing like the satisfaction of doing something yourself...ain't that right bigaudio?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • bigaudiofanatic
    edited August 2010
    It is not like we filled it wil high tes every time but once in a while my dad would get it.
    My plans are to do a engine swap next year but this year I am going to clean it up and in the winter I am going to remove EVERYTHING and send the body for paint. My girl friends grandfather knows someone with a paint and body shop and I can get any color I want for around 500. Than while it is getting that done I am going to be in search for a new engine like a mazda 323 or even a mita engine.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • kawizx9r
    edited August 2010
    Heard of Monster Miata's? :p
    Wonder if the same can be had for the Capri, don't know how much room you've got to work with there...hmmm
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • bigaudiofanatic
    edited August 2010
    kawizx9r wrote: »
    ^+1
    Yep you got that right. Also forgot to say that I will be helping in the paint booth as well. :D
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
