KIMBER kABLE TERMINATION
gwh
gwh Posts: 1,451
i'VE BOUGHT SOME UNTERMINATED KIMBER KABLE (4VS) OFF EBAY AND WOULD LIKE TO KNOW IF I SHOULD USE SPADES OR PLUGS ON THE ENDS. I HAVE A DENNON RECEIVER AND WILL BE RUNNING THE CABLE TO RTI38'S AND BI-WIRING A CSI40.
AS FOR QUALITY, WOULD A GOLD PLATED CONNECTOR FROM RADIOSHACK WORK OR SHOULD I LOOK ELSEWHERE?
THANKS FOR YOUR TIME!
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
    F1nut Posts: 51,761
    edited December 2003
    Either choice will work for the ends, but make sure your Denon and speakers will accept them.
    Please don't use caps, it's rude.
  • mantis
    mantis Posts: 17,374
    Denon receivers don't except spades,use banana ends for best results.Kimbers ends are very nice and well built.
    Dan
