Audioquest cables
  • zippty2001
    zippty2001 Posts: 232
    edited August 2010
    i have about 5 boxes of CAT-5 thats what i made all my speaker wire from used the solid copper it works well for the price
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2010
    zippty2001 wrote: »
    Are you referring to this method of using CAT-5?
    http://www.venhaus1.com/diycatfivecables.html
  • zippty2001
    edited August 2010
    well i did not know that was around. but something close i just thought cat 5 is is good copper should make good wire so i have about 4 lines 2 for + 2 for _ braided and banana plugged ...
  • mole'
    mole' Posts: 3,160
    edited August 2010
    my AQ King Cobras and Sidewinders showed up today
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    i have hooked up the new AQ and cant really hear a difference from the older MonoPrice cables i had hooked up.
    i have them running from my AVR to my Acurus amp.
    mole'
  • concealer404
    concealer404 Posts: 7,440
    edited August 2010
    List the cables you're running through your whole system.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    MIT AVt-3 fronts
    MIT EXp-1 center
    MonoPrice 12 AWG/MP bananas rear
    AQ King Kobra
    AQ Sidewinders
    MonoPrice HDMI
    stock power cables
    mole'
  • concealer404
    edited August 2010
    baleeted, double post.
  • acmf74
    acmf74 Posts: 937
    edited August 2010
    mole' wrote: »
    wow.... if or when I get an additional amp I want to try out various cables. AQ and Mono are def the ones i want to test.
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited August 2010
    I could hear a difference when I switched from the 12 gauge monoprice to my Rocket 33s. It was almost instant. The sound stage was a lot clearer, and it just seemed more defined...and realistic...
    The monoprice just seemed dull and boring afterwards
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • concealer404
    edited August 2010
    I think you've just got such a hodgepodge there that you're having a hard time hearing anything.
  • PerfectCreature
    edited August 2010
    Is that referring to me?
    You can hear the difference between the two.
    It is not huge, but there is one.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • concealer404
    edited August 2010
    Nah, to Mole'.
    He's changed everything willy-nilly without giving anything burn in time, and nothing matches, he's got all kinds of different "sonic signatures" going on in there.
    On the flip side, he's going from entry-level cheap monoprice cables to entry-level AQ cables. Considering he's got MIT stuff through the rest, i wouldn't expect to hear a HUGE difference, either.
  • PerfectCreature
    edited August 2010
    Oh, I was going to say...all my stuff matches. I run all audioquest.
    My sub cable is entry level. My Optical is mid grade, along with my speaker cables.
    I mean, he should be able to hear a difference, I know I did. But then again,I also bought my Rocket 33s used so I did not have to worry about burn in. I just had to clean the tarnish off the connectors. ha.
    That is another thing. Keep those connectors clean.
    Invest in some Deoxit before you need to use it.
    Have you taken the time to individually place each speaker where it sounds the best to you when you are in the sitting position, and then see how it sounds with say, the fronts where they are, and then the rears, and then all together.
    Placement can have a huge effect on weather it sounds good or not to you.
    You can **** all the high tech stuff you want but in the end remember it is what sounds best to you....
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • mole'
    mole' Posts: 3,160
    edited August 2010
    i <3 you
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    he was talking to me
    Nah, to Mole'.
    so it would be best to have all the same brand? i can still get that deal on the AQ CV-8 cables.
    how do they compare to the MIT AVt-3.EXp-1 ?
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    i am running a low level Monitor speakers aswell. so maybe thats it too.
    i have more $$$ in all my cables than i do into my speakers for now
    and just to make sure
    i said i heard no difference going from MonoPrice ICs to the AQ ICs (sidewinders and king cobras)
    i just hooked up the MIT AVt-3 (did not hook up the EXp-1 cause i did not have enough bananas) and they have about 20 hours on them so far. but so far they sound good over the Monoprice 12 AGW wires
    mole'
  • PerfectCreature
    edited August 2010
    I don't know if I believe in that DB system or not.... I could have gotten mine with them, i still can for about $80 AQ will do it for me.
    Anyway. It really is up to you. It is best to try to stick with the same cables just because they are generally made with the same types of materials, and each manufacture does things differently.
    Again, are you going to notice the difference between spending say $500 on MIT cables or getting a deal on the CV-8s for say...$250 probably not.
    If you can get the CV-8s for cheap they will do just as well as if you got the MITs.
    MIT will be there, it is not a company that is doing bad. Your system will grow, and so will your tastes and speakers. For now the CV-8s will do you just fine.
    I would not worry about cables this early in the game. Your system is still growing.
    When you get some higher end speakers like the RTi line, or some PSB speakers then it could matter between a lower level AQ and a higher level AQ.
    But for now, just take the deal and listen to your music.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • concealer404
    edited August 2010
    mole' wrote: »
    Nah, i wouldn't say necessarily that it's "best" to have all the same brand, but it sure is easier, i'll tell you that much. :p But give it some time, and if you still don't notice a difference, then accept the fact that in your case, the AQ cables weren't a noticeable improvement over the monoprices, and stick the monoprices back in, get the money back out of the AQs. If you like what you hear and you're happy with it, then keep them in. Don't upgrade just for the sake of upgrading/spending more money. If you like what you hear, then sit in that spot and LISTEN and be happy. ;)
    I can't comment on the speaker cables, i haven't had either unfortunately. CV-8s are on my short list whenever i get around to paying attention to my rig again in the future though. Probably not for another 3-4 months.
  • concealer404
    edited August 2010
    mole' wrote: »
    That may be part of it. There's always a weak point. If that's the case, then i wouldn't ditch the AQs just yet, and maybe re-visit the experiment later on with different speakers if that's what you want to do.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    i shall find out when i hook up the SDA SRS 2.3TL's here soon.
    thanks for the info guys
    mole'
  • PerfectCreature
    edited August 2010
    Well, In any case. I wish you luck.
    Hopefully those speakers will yield the results you were looking for.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited August 2010
    Nah, x is amusing me now. It's hilarious looking on as he makes himself out to be foolish. Every time he posts it's like he babbling from his bungus. It's funny! And he doesn't even have sense enough to realize it. Great entertainment
    Almost as amusing as those who create an account just to post links.
    Reported.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    WilliamM2 wrote: »
    Reported.
    i reported him as well.
    mole'
  • cheif pontiac
    cheif pontiac Posts: 138
    edited August 2010
    I think Mole' is the Borg.
    System:
    Samsung LN46C630
    Receiver: Yamaha RX-V1
    DVD/Blu: Denon 2910/Playstation 3
    Front mains: RT16
    Front presence: F/X 500i
    Center: CS400
    Rear surrounds: RT1000p
    Rear center: RT7
    Subwoofer: PSW505 X 2
    Marantz 2252B
    Technics SL-Q2 turntable
    Kef Q50
  • Outfitter03
    Outfitter03 Posts: 563
    edited August 2010
    Resistance is futile. I will assimilate all of your audio gear!!!
    But only after I buy it. LOL
