SDA 1C Vs Studio 1C?
i4gotmyid
i4gotmyid Posts: 173
edited December 2003 in Speakers
I just got my grubby hands on a mint pair of Studio 1C's with upgraded tweeters to the sl3000's. So I was wondering what the diff was between these and the regular 1C's and also the 1B's as they look similar to the 1B's, except for the pin-blade cable.
Post edited by i4gotmyid on
  • hoosier21
    hoosier21 Posts: 4,428
    the studio version is the same guts but does not have the top and bottom wood caps, and the side grill cloth.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • dorokusai
    dorokusai Posts: 25,627
    You also might want to pull the crossover and make sure that was "upgraded" also. The values change for the tweeter between the SL2000 and the SL3000. Nice find, but also a even harder tweeter to source.
  • i4gotmyid
    thats the only reason i bought it cause i never find any sl3000's.
    does anyone have a pic of the orginal x-over so i can see if changes were made to mine?
    F1nut Posts: 52,244
    If you email or PM me your email addy, I have a stock 1C schematic I will send you and Doro has a 1C schematic modded for SL3000's that I will get from him, scan and send you. That way if your xovers aren't upgraded you can do it.
