Projectors People
13
  • kuntasensei
    kuntasensei Posts: 3,263
    edited August 2010
    Nice looking install, man. Makes me want to redo mine!
    (But why the hell aren't you getting much use out of your rear surrounds? I run 9.2 full time, and my rear surrounds get a ton of use. Or are you a 5.1 purist?)
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Ricardo
    Ricardo Posts: 10,636
    edited August 2010
    I do use the surrounds back when watching TV, but not that much with movies. There are not that many DVD's or Blurays that have more than 5.1
    SOPA
  • kuntasensei
    edited August 2010
    Ricardo wrote: »
    Yeah... but Dolby does recommend using DPL-IIx for anything with 5.1 EX... which is damn near every new release for several years now, even if it isn't flagged as such. Because movies have been mixed for 5.1 EX in the theater for years now, there is a benefit to leaving DPL-IIx engaged full time for recent releases. Just because it has a 5.1 track on the disc, that doesn't mean that sticking to 5.1 gives you the same presentation as in the theater since most theaters leave their rear matrixing on.
    Hit Dolby's podcast: http://www.dolby.com/consumer/experience/dolbycast/transcript/11-surround-sound-from-stereo.html
    Equipment list:
    Emotiva XPA-3 amp
  • Ricardo
    edited August 2010
    Then I need to see how to setup my player/AVR, because whatever I do it defaults to 5.1 if the DVD/bluray is 5.1
    SOPA
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2010
    i'm late to the game but it seems you got good feedback and advice already. looking sweet thus far. have you projected onto the wall for **** n giggles? do this, and then you'll appreciate the screen that much more when it arrives.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Ricardo
    edited August 2010
    BIZILL wrote: »
    Nope. Don't have a long enough cable yet. Tomorrow I should get my HDMI from Monoprice and you can be damn sure that as soon as it gets here I'm projecting to the wall ;)
    SOPA
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2010
    just a heads up, i have the 22ga (whatever the thickest they offer is, i forget) 50' hdmi cable from monoprice and have no repeater and no issues. i have and 6 components in my hdmi chain without issue. maybe it's the onkyo receiver, dunno.
    man, wasn't long ago i was asking these chaps the same things you're asking and boy am i impressed. daddy got the biggest screen on the block, baby! i did however, have to paint my walls darker. but this was a plus as i needed to paint anyway. i went all out with black, but am left with a white "popcorn" ceiling and light beige tile. i can add a carpet to block the reflection off the tile but the ceiling will be left alone for now.
    i doubt you'll need to paint, but IF you choose to, you'll be near-amazed with the results. but again, not a necessity. you will be able to use a lower bulb setting and save hours on the life if you do.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
    billbillw Posts: 7,563
    edited August 2010
    Ricardo wrote: »
    Use PLIIx, it will fill in your rears perfectly and leave the rest of 5.1 untouched. You can use it with just about everything except for a 6.1 signal which is pretty rare these days.
  • Ricardo
    edited August 2010
    BIZILL wrote: »
    I got the 22 ga; Will try it alone and see. I also got the repeater, for 12 bucks I figured I could as well have it just in case.
    billbillw wrote: »
    As I said, I need to check my settings. I must have some auto setting somewhere because I can't change what's coming from the DVD players.
    SOPA
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2010
    BIZILL wrote: »
    No you don't! You have the widest screen, your 16:9 image is way smaller than mine. It's a compromise buddy, get it right. I have the biggest screen technically speaking. Gotta admit you have a garbage projector though. :rolleyes:;):D
    Edit: Anyway Ricardo things are moving fast in there. Awesome bro. Mounting looks fantastic. If you have problems with the long HDMI, the equalizer or booster should get things right for you. As from Monoprice
    http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10419&cs_id=1041907&p_id=3394&seq=1&format=2
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2010
    Make sure you post sone pics when you get everything setup.
    Enjoy!!!!
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2010
    Sherardp wrote: »
    naw, daddy got the biggest screen in my own personal neighborhood. regardless, i may have the biggest 2.35:1 screen here, though??? perhaps not.
    ricardo, a note about the hdmi cord, this beotch is THICK baby. and it does not like to bend or flex much at all. you said there are bends that need to be made, but judging by your showcase pics, i don't see where you'll have any issues. for me it was hard fishing the cable from the attic where i was feeling like a contortionist down through the wall that was already chock-full of other speaker wires, rg6 cable and the like. but otherwise, it went well.
    when fishing it down through the stem of the ceiling mount, it got a bit dicey. but since i'm just that cool, i made it work, and work well. then i made a lazy 90 degree bend....or arc, rather and plugged it into the back of my projector. i am thinking you MAY have an issue there. with that projector and that shallow rack, i'm wondering if you're gonna hit the wall with the hdmi cord or perhaps you'll be able to just give it a good bend by hand.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • Sherardp
    edited August 2010
    BIZILL wrote: »
    I gotta give you a hard time man. Where the heck have you and Demi been bro? I never see you guys online anymore and it kinda sucks cause we got to talk shop quite a bit over Xbox Live man.
  • Ricardo
    edited August 2010
    BIZILL wrote: »
    Not good. The route I'm planning is pretty intricate. I guess I'll have to open a few holes in the drywall to help me get through the tough spots and pull in stages.
    Oh..that means I would need to patch and PAINT....maybe there will be an irresistible offer in dark colors only ....;)
    SOPA
  • Sherardp
    edited August 2010
    I'm looking forward to seeing the project done and hearing your thoughts on going front projection.
  • kuntasensei
    edited August 2010
    I strongly recommend using an HDMI port saver if you're close to the wall. I used one so I could make my cable run parallel to the wall to a wall plate, and it works like a charm.
    Also, if you're using wall plates, the HDMI plates from Monoprice that have a flexible 4" connector work great for hooking up that thick HDMI cable on both ends. Kept me from having to go crazy with bending.
    Equipment list:
    Emotiva XPA-3 amp
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited August 2010
    "Sure, in those cases you don't want to get bent out of shape" ;)
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Grimster74
    Grimster74 Posts: 2,577
    edited August 2010
    Ricardo, I own an Elite screen and if your on a budget, Elite is the way to go. After I purchased my Elite screen I had many other manufactures send me samples of their screen material which was roughly the size of a sheet of paper and to be completely honest with you, I really didn't see a difference when compared to the Elite material. Save the extra coin to purchase new movies to enjoy on your new screen and projector and buy an Elite, you won't be disappointed.
  • Sherardp
    edited August 2010
    Grimster74 wrote: »
    Your a little late bro, he ordered the Carada.
  • TECHNOKID
    edited August 2010
    Where were you when the men needed you ;)
    DARE TO SOAR:
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2010
    sherard, i haven't felt the urge in forever. i suck at codmw2 now anyway. also now that the kids are living with me again, they've taken over my ht and my sda's. :(
    grim, like i was saying to you, you have the better higher gain material. the less expensive but always referred to fixed frame elite screens are not up to par with yours. yours is the shiznit.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • Ricardo
    edited August 2010
    1.- Who needs a screen. This thing looks awesome on the wall, and it's a light brown wall (There was movement and with no flash the image does not look as good in the picture).
    2.-The Monoprice cable is actually very thick. I'm going to have lots of fun tomorrow.
    3.- This thing looks awesome!!!!
    SOPA
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2010
    4. good job ricardo!
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • cstmar01
    cstmar01 Posts: 4,424
    edited August 2010
  • TECHNOKID
    edited August 2010
    It's really getting there, you are pretty quick to act once your decision is made. You seem just as exited as we are (PJ folks) so I don't think you are gone a look back, you are now a PJ man and forever :cool:
    DARE TO SOAR:
  • Sherardp
    edited August 2010
    Awesoem Ricardo. Once you get the screen you'll notice more detail and have a better image overall. Congrats on going with the "bigger picture".
  • Grimster74
    edited August 2010
    Yeah, no kidding, I didn't even pay any attention. Been having a pretty rough couple of months lately so I didn't even pay attention. Congrats on all your new purchases though and enjoy.
  • kuntasensei
    edited August 2010
    Congrats, Ricardo! Like the guys said... There's no going back once you go projection. The major side-effect will be a complete unwillingness to suffer through the horror of an actual movie theater anymore. Burn yourself a copy of the AVS 709HD disc and you can tweak that projector to get every ounce of awesomeness out of it.
    Equipment list:
    Emotiva XPA-3 amp
  • Ricardo
    edited August 2010
    Done. Putting the screen together was pretty easy. It does make a huge difference in the image.
    Just need to clean up and patch a couple of holes in the wall :(
    Images are from TV.
    SOPA
  • Ricardo
    edited August 2010
    So I just have two questions to finish this thread:
    1) Why would anyone that has the space for a projector own a TV???
    2) Why didn't I do this earlier????
    For those that are thinking about it, this setup was actually cheaper than many TV's out there. Less than $2,000 and I chose a relatively expensive screen. You could do it for $1,500!!!
    Thanks for all the help guys. There is really no going back!!!
    SOPA
