Today's finds....
Paradigm Mini Monitors v2 - $20
2 Technics Digital tuners, 1 Onkyo - $10 for the lot
Anyone else have any recent finds?
Post edited by RuSsMaN on
Is that from your local SevenEleven House of Pawn, Mark?
Nice score there you freak Texan.
George Grand (of the Jersey Grands)
"Hey big man let me hold a dollar"
How do they sound? Don't put any real power to them, but if you are ok with the tweeter tonal signature, then yes, they are worth keeping. I'm not familar off hand with the 1200, is it a dome tweet, or a horn job?
I've told you guys how I do it, they key is consistency, and opening your pie hole to ask questions. On the p-dimes, this was the 8th time I had visited this particular pawn shop in 6 weeks or so. The past 7 visits, NOTHING. (the visit prior to said 8 was the Boston A100 score that needed foam for $9.) I'm there about once a week, and if I don't see anything on the shelf, I ask whats about to get put out.
Cheers,
Rooster
These are horn loaded with a 12 inch woofer and 5 1/2 inch cone mid, my son and I had them hooked up last night and the horn is very smooth, not typical behavior for a horn plus there are adjustments for the mid and horn on the front of the cabinet so I can attenuate if need be. If p.e. still sells the stuff I may order some of the treatment for paper cones, you just put it on with a good quality paint brush and it gives you the look of the older polk drivers. I guess that it gives some damping to the cone surface and helps protect them from drying out.
Tour...
Vox Copuli
