Monitor 70 Stands
fused
fused Posts: 4
edited August 2010 in Speakers
Does anyone know of any stands that will work with Monitor 70s? I'm using M70s as my surround backs and need to raise them a few feet so they aren't being blocked by my back row recliners.
Post edited by fused on
  • Dabutcher
    Dabutcher Posts: 2,624
    edited August 2010
    Keep in mind that you want to keep your tweeters at ear level as much as possible. Maybe just build up with an eight inch wood riser that you make? Good luck,D
  • Dobermann
    Dobermann Posts: 84
    edited August 2010
    A few feet?
    Honestly, I would get rid of them and use the money to buy some bookshelves that you can easily mount on the wall.
  • sandworms
    sandworms Posts: 1,043
    edited August 2010
    you want to raise your towers above your recliner? you would need to go 4-5 feet just to give all your drivers exposure. I doubt you'll find commercially available stands. Like dabutch says you will have to custom make something or do a search for stands on here, I think I saw some sturdy ones here http://www.audioconnect.com/target-mr-series.jpg
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
